The gear is difficult
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 406
08.05.2020 18:25 # 1
alp-han
Hello, I have 98 sv 406 and there has been a problem for a while. Not always, but occasionally it is very difficult to shift to 1st gear. Does anyone have knowledge or knowledge at the same time in the low or the same?
08.05.2020 18:25 # 2
Bugra
Even if the vehicle is very moving, 1 gear is usually difficult. When it is hot, it makes a difference when it is cold.
08.05.2020 18:25 # 3
Genc12
get well soon bro you solve the problem as soon as possible insha'Allah
08.05.2020 18:25 # 4
inciboncuk
I am glad I became a member here. I had the same problem when it was cold. So does it have to be changed from the gearbox oil?
08.05.2020 18:25 # 5
E.B
Just like my friend, you need to change the oil, it will be like cotton after changing it, but be careful if you do it while on the move, it is normal that it will not go away :)
08.05.2020 18:25 # 6
sezar206
You can hardly wear oil on the move when it is cold. Even if the transmission moves slowly when it gets a little warmer, you should install the vehicle, and when the vehicle is stopped, you must have a cold or hot click.
