The front right side of my vehicle is 1 cm lower HELP
08.05.2020 14:16 # 1
tazzzy106
friends front right side of my car is 1 cm lower why do you think .. i put zero spring .. no accident .. can you please help ??
08.05.2020 14:16 # 2
BAHTIYAR
tire pressure, bumper or fender screws may be loose, these are simple reasons I don't know more in my mind.
08.05.2020 14:16 # 3
tazzzy106
But the distance between the fender and the tire is about 1 cm different.
08.05.2020 14:16 # 4
tazzzy106
friends please I'm waiting for help ..
08.05.2020 14:16 # 5
MirakGTI
Is the place where you stand right straight?
I say look at torsions
08.05.2020 14:16 # 6
tazzzy106
torsions are adjusted, they have no problem .. only left front stands low yes on flat ground ..
The gap between tire and fender is different from each other. There is a difference of 1 cm.
said the master shock absorber, but what should I know? shock absorber ...: s
08.05.2020 14:16 # 7
tazzzy106
sorry right front low ...
08.05.2020 14:16 # 8
It is not possible to see the difference of 1 cm. I am a lathe. It is noticeable that it should be more in the diesel. The shock absorber is the original springs. The same equation method is measured. Press down the left side of the vehicle with your hand. Detect the shock absorber gap.
08.05.2020 14:16 # 9
tazzzy106
I noticed when applying the polisher to the tires .. it was not before .. but for a short time, I used it with a very short spring for about 1 week, the shock absorbers made a striking shot .. then I bought a zero spring .. I made the rott settings. it is evident from the bumper effect on flat ground.
It is evident in the gap between the tire and the windshield. 1 cm is very comfortable with the eye ...
08.05.2020 14:16 # 10
Long Beach
Shock absorber - shock absorber tower + tires, if. If the tires are of the same brand + cap and outer ratio, and look at the tie rod settings first.
08.05.2020 14:16 # 11
tazzzy106
Will it happen when the shock absorbers break down? If one side is worse, will there be a collapse in this way ??
08.05.2020 14:16 # 12
Long Beach
[QUOTE = tazzzy106]
Possibly, of course, also; shock absorbers change double, not individually.
If it changes one by one, situations like yours are likely to occur.
First, look at the rod settings
And
I also wrote you my opinion before buying a bow. Reasons etc.
This word always proves itself.
Buying cheap takes twice
Long beach 2010-06-07 20:24:01
08.05.2020 14:16 # 13
tazzzy106
The rott settings are new .. the front tool is made .. the rott setting is done .. there is no problem outside this curvature ..
my master said that the shock absorbers are broken but we postponed it .. I think it was from him .. :( but I wanted to reach a definite conclusion ..
I mean, I think if I entered the pit fln I have broken the tower balance, but this is not something that is easy, so ..: S I do not know, I will go crazy ...
08.05.2020 14:16 # 14
Long Beach
Shock absorbers are not only double,
You should definitely buy SPORTS SHOCK ABSORBER , the reason;
sports shock absorbers are shorter than standard shock absorbers.
AND
ABSOLUTELY, oil-gas-salt suppression, as some mentally conceived,
like a tornacida pants pacemaker, do not cut or shorten,
you are harmful both technically and financially.
My shock absorber recommendation; (gaseous)
1 - Cone (orange)
2- Bilstein
3_ Sachs
Monroe
08.05.2020 14:16 # 15
tazzzy106
So my problem is you say the ABSOLUTE shock absorber ...
then you have to buy 2 monreos ... am I right ???
08.05.2020 14:16 # 16
Long Beach
greetings,
I am writing again
if the ;
If there is no problem with the rods, if there is no problem with the shock absorber upper and lower rubber blocks,
if the buffer-mudflaps is one down, one is not up,
There is no other choice, your master has already said that he is a shock absorber.
This is the conclusion that I have drawn from your account.
Two gas springs, if you use it with a short spring
ORIGINAL SHORT (SPORT) shock absorber,
GAZLA-TUZLA- this time with the shortening like a trouser pac,
It ends at the police station or at the grave whether Allah gives it. This job is not a problem.
After a short spring + shock absorber, you MUST STRICTLY ROTE THE ROUTE SETTINGS.
If there is (ABS) settings, brake settings should be made again. You change the car's center of gravity and center pain. Even those who do not break the physics class in high school know what this means.
08.05.2020 14:16 # 17
tazzzy106
shock absorber top plates and balls have just changed .. suspension rods rott heads have just changed ..
I had some unchanged dampers :(
I understand, I am tsk for the information .. I am changing the shock absorbers as soon as possible ..
08.05.2020 14:16 # 18
Long Beach
yahu it is the only problem in life Sırıtma May Allah not give you any trouble Göz Kırpma
To guarantee your work, make the change to the recommended master.
08.05.2020 14:16 # 19
tazzzy106
I don't know walla, I'm a little bit nervous, I didn't sleep like this :(
08.05.2020 14:16 # 20
Can Duzyatan
Behold, they say "it doesn't crack so much water"
Don't worry and don't worry Gülme
If you want to find a solution, eat plenty, gain some weight, dear Omer. Sırıtma
Page : / 2
