the frequency of adding antifreeze
22.11.2020 20:08 # 1
Bayer
207 1.6 140,000km How many km should antifreeze be added under normal conditions? Although I haven't driven a lot of kilometers lately, every time I check I see that the antifreeze level is minimized and I pour it to the maximum. I'm using the shell's red one. I will then calculate how many km decrease by 1. How much do you put in? How many km is this normal? I suspect there is a leak. Do you have any other antifreeze brand / color suggestions? Good evening.
22.11.2020 21:06 # 2
ismailkaya
There was a leak in your vehicle, check the hoses, check the radiators and the lpg water hoses, if there was a leak in me.
22.11.2020 21:27 # 3
talip206
If there is no leak, the water will not decrease. Engine cooling water is closed-circuit, so depending on usage, decrease etc. should not be.
22.11.2020 21:42 # 4
Bayer
Normal gasoline, not LPG. If there is a leak, then we need to take it to the master? How much is the estimated cost?
22.11.2020 23:35 # 5
ismailkaya
We do not know first of all, let's see if he is missing from the water, whether the oil is mixed with the water.
