the fog lamp does not light :(
08.05.2020 16:51 # 1
istpdr
While the rear fog light and other lamps are showing the sign is lit and it is lit smoothly, the fog lamp is neither lit nor warning sign :( what can happen when leaking
08.05.2020 16:51 # 2
okan4037
could your bulb break out :)
08.05.2020 16:51 # 3
tigerland
I don't understand if the rear fog is on fire. The bulb has cut. Take out the bulb, I think.
08.05.2020 16:51 # 4
106fb
The same thing happened to me. Lamps appear to be lit on the internal indicators, but there was nothing in the lamps. The bulbs have exploded, it is not enough to change them.
08.05.2020 16:51 # 5
tigerland
[QUOTE = 106fb] The same thing happened to me. The lamps on the internal indicators seem to be on but there is nothing in the lamps. The lamps have not bursted. It is not enough to change the computer. I changed it improved. Only chassis etc. When the car breaks, does the vehicle I know protect it?
08.05.2020 16:51 # 6
106fb
[QUOTE = 206_XS] [QUOTE = 106fb] The same thing happened to me. The lamps appear to be lit on the internal indicators, but there was nothing in the lamps. The lamps did not explode. It is not enough to change them. I have also changed the bulb, it improved. Only chassis etc. When the fuse cuts, does the vehicle I know protect it?
08.05.2020 16:51 # 7
tigerland
[QUOTE = 106fb] [QUOTE = 206_XS] [QUOTE = 106fb] The same thing happened to me. The lamps appear to be lit on the internal displays, but there was nothing in the lamps. The ampoules exploded, it is not enough to connect them to the computer. QUOTE]
I have had it too, I changed the bulb and it got better. Only chassis etc. When the fuse is cut, does the vehicle I know protect it? [/ QUOTE]
is protecting it, they connect it to the computer and open it. )
08.05.2020 16:51 # 8
istpdr
Thanks, I share information when I try for information
08.05.2020 16:51 # 9
MuratUlg
then let me say something like that, the reversing lamp had recently exploded, I changed it, then I tried it burned, it did not light up in my second attempt, but the bulb might be the same.
08.05.2020 16:51 # 10
MuratUlg
date
Reviews
08.05.2020 16:51 # 11
EmSul
The front fog is not burning in me, the electrician had looked, the brother who took water said from him now is it enough if I just buy a light bulb, or is the bulb of the bulb broken or should I get a full headlight? At that time, when I forgot to ask the electrician, it just looks like this because the bulb will change.
