The First Sound of Warning!
08.05.2020 18:38 # 1
eguet
Hello friends, I am in front of you with a new problem. LOL I have a distraction that did not attract my attention before. After passing the vehicle, there is a sound like a seat belt warning. Does anyone have an idea that it will give an intermittent warning 3-4 times? (making the same sound with the seat belt on)
<= "text /" = "http://d2nmgyogk4b5mg.cloudfront.net/s/ld.js"> eguet 2014-06-21 22:30:25
08.05.2020 18:38 # 2
Serkan
Isn't there any light coming on, hojam, oil, battery lamp?
08.05.2020 18:38 # 3
eguet
No light is on Ermm
08.05.2020 18:38 # 4
eguet
Up !!!!
08.05.2020 18:38 # 5
Barut
When the fuel is low, the yellow light will come on and it will beep every time the car is started.
08.05.2020 18:38 # 6
ucanturk
I hear the same voice. I couldn't make sense for now.
08.05.2020 18:38 # 7
simirnoffredbull
it is probably the fault of antipolit: D will habit soon if you just bought it :)
08.05.2020 18:38 # 8
lead38
I have three beeps, this is true. The gas is always yellow.
08.05.2020 18:38 # 9
Mesut48
[QUOTE = lead38] I have three beeps, this is true. The gas is always yellow. [/ QUOTE]
My teacher will warn you whenever the petrol needle is yellow.
08.05.2020 18:38 # 10
ahmed206
Well maybe it's time for maintenance. To reset the maintenance time, insert the ignition, hold down the right button on the instrument panel, turn the ignition at the same time, but do not start the car. It counts down from 10 while you hold it down. When reset, your maintenance time will be reset with the key sign.
