The fan is constantly running
08.05.2020 21:07 # 1
Levent23
Greetings, I am actually a new 407 seven user. The engine cooling fan, which attracts my attention, runs the vehicle. it does not work, it raises and lowers the speed but it is not active.
08.05.2020 21:07 # 2
talip206
it is absurd to start the fan at low temperatures. Because, let me give an example, if it opens at 85 degrees, it starts when the thermostat opens in the circulation. In a situation where the thermostat does not open, even if the fan works as much as it wishes, it will not be useful because the radiator is already cold since the circulation does not start.
If the air conditioner does not work, check the fan roles. In general, when there is a problem in fan / air conditioner roles, it may not be activated in the air conditioner.
It is also useful to check the temperature sensor and fan resistance.
If the air conditioner does not have gas, it may not be activated. Or, if your location is too cold, the air conditioner may not be activated.
I have no idea about speed stabilization.
talip206 2018-12-29 23:26:15
08.05.2020 21:07 # 3
Levent23
aspiring 206 brothers, I also agree, thank you in these beautiful ideas.
08.05.2020 21:07 # 4
platinium306
First of all, get past. I had the same problem in my 306 recently, I changed the temperature sensor and the problem was solved.
08.05.2020 21:07 # 5
Levent23
There are those who say that it works normally, I don't know clearly, but I think it shouldn't work - the engine is cold in the 8's already
08.05.2020 21:07 # 6
Ufuk_64
I do not know the fan event, but the air conditioner below +3 degrees is not activated in most vehicles.
08.05.2020 21:07 # 7
your teacher should not work, your potential temperature sensor - fan resistance may be defective. braking sensor may be the reason for cruise control not working. The vehicle should be scanned with the original peugeot software. many universal diagnostic devices cannot see many errors. sonerkyl 2018-12-31 09:14:28
08.05.2020 21:07 # 8
KILIC
The diesel engine is already warm at night, and if the fan is activated, it will not heat up. If it does not reach the ideal temperature, both performance decreases and damages the engine and your fuel increases. As the friends say, the temperature sensor may be impaired.
08.05.2020 21:07 # 9
Levent23
I had the vehicle connected to the device in the authorized service. The brake did not fail with the customer or something. It was necessary to try the control lever.
08.05.2020 21:07 # 10
then you have to buy a zero arm to test it.
08.05.2020 21:07 # 11
necmettinn
I think I am writing with the possibility of being tried at low speed, you know, but speed stabilization does not come under 70km. It enters when watching over 70km. Hopefully it is not defective.
In the case of a fan, I think the same as friends can be a thermostat. Have a nice day...
08.05.2020 21:07 # 12
Levent23
My brother ordered the cruise control arm, alone, my armrest was broken, I was looking for more than aliexpres, I couldn't find it.
08.05.2020 21:07 # 13
Levent23
[QUOTE = necmettinn] I think I think it might have been tried at low speed, you know, but you do not know that speed stabilization does not come under 70km. It enters when watching over 70km. Hopefully it is not defective.
I tried 4 and 5 gears over 70 km, unfortunately, it does not enter
08.05.2020 21:07 # 14
LUDACRIS
At 407, the cruise control operates from 4th gear and 40km / h speed.
If we come to the fan event, there is a possibility that there will be no malfunction. As far as I know, in 407 extra
There is a system to handle the internal heat quickly. So it may be working. Diesel car heats up late
Can reach for 407 parts Thumbs Up
08.05.2020 21:07 # 15
Levent23
[QUOTE = LUDACRIS] At 407, the cruise control operates at 4th gear and 40km / h.
Can i have no
08.05.2020 21:07 # 16
LUDACRIS
[QUOTE = Levent23] [QUOTE = LUDACRIS] At 407, the cruise control operates from 4th gear and 40km / h speed.
Can i have no
I sent a message
08.05.2020 21:07 # 17
LUDACRIS
Can i have no
Levent?
22.05.2021 03:47 # 18
Sahnank
Hello my master soner
I found you on the form site, my vehicle 2014 C elysee is constantly failing and the fan is turning on extremely constantly, I stop it by removing the terminal, it falls from the traction and protects itself. The thermostat sensor was changed, but it was not a solution. I have a wedding soon. I have a job with a car all the time and this bothers me a lot. Can you help me with this? I would be very pleased if you contact me as soon as possible on this number 0534 043 8556.
