The evil of the 4 provinces
08.05.2020 19:44 # 1
selim38
As you know, I own 2003 307 xt and I was out of the city at the weekend and I faced the disadvantage of 4 provinces high speed problem 130 to 3000 3500 rpm is perfectly nice but at 130-180 speeds 3500 4500 rpm is a complete torture engine officially says 5e at 5 but 5 at no I said how I was screaming at that moment, I wish I could get the 5th gear, whatever it was.
Note: speed is bad even if we did it on the highway.
08.05.2020 19:44 # 2
fætih
Mine is yelling manually in ours. Every atmospheric gasoline car that turns cycle shouts at high revs. 4-speed automatic 5-speed manual does not matter ...
08.05.2020 19:44 # 3
mimit
this is not a gearbox-related situation, it is not only related to the engine and weight, but the 2.0 406 also uses the same gearbox, but at the end of 3rd gear, he sees 190 very comfortably, after 4pm, acceleration after 210 is quite slow, the vehicle can be 4 forward but the gear ranges It is adjusted according to the size. A 5-speed vehicle can accelerate to 50 km max in 1st gear, while my vehicle speeds around 70 km.
08.05.2020 19:44 # 4
selim38
I did not want to tell you how long it takes to speed, but it does not affect the pleasant driving that I want to tell you, the road is fixed to 140, because the speed is high, the engine disturbs the sound.
08.05.2020 19:44 # 5
mimit
But here is the speed of a spike by the 4th gear at 2500 rpm, unless your vehicle has a wide gear range, i.e. very high speeds.
