the evil eye was worth the cylinder head gasket ..
08.05.2020 15:36 # 1
dinoco
When stopping, an oil sweat or a leg occurred from the cylinder head gasket.
As we know, we pulled the door immediately, the door became sore, the gasket changed, etc. VB 350 will hold 400 400 TL.
nabal can not come to life :))
08.05.2020 15:36 # 2
[QUOTE = dinoco] oil sweat or leg occurred from the cylinder head gasket while stopping.
Did you notice this when checking your vehicle? How was it?
Get past it.
Koliva 2011-06-12 15:54:45
08.05.2020 15:36 # 3
GokhaN
thank goodness for larger expenses Gülme
08.05.2020 15:36 # 4
dinoco
my partner is already using the tool. I came to my workplace parketti vehicle stopped from afternoon until the evening, I looked at the oil, there was a handful of size under it .. I looked down, oil was dripping .. I called the service. They said the cylinder head, they took it and went. It was evening, I went to the service, the cylinder head gasket was changing. Because I was going to go home every Saturday Saturday evening .. everyone should not be bloated. Dinoco 2011-06-12 16:04:44
08.05.2020 15:36 # 5
GokhaN
The tool [QUOTE = dinoco] already uses my partner. I came to my workplace parketti vehicle stopped from afternoon until the evening, I looked at the oil, there was a handful of size under it .. I looked down, oil was dripping .. I called the service. They said the cylinder head, they took it and went. It was evening, I went to the service, the cylinder head gasket was changing. Because I am going to go home everybody on Saturday evening.
No rush to do any of the best work you've done anyway.
again get well soon.
08.05.2020 15:36 # 6
dinoco
Thank you for your good wishes. Dinoco 2011-06-12 16:19:57
08.05.2020 15:36 # 7
metin
brother get well soon. the cylinder head gasket was going to change, but the master tried to defraud the loosening of the oil drain, we were getting rid of the oil. We tightened the oil drain and no oil since
08.05.2020 15:36 # 8
dinoco
Thank you text my friend is correct
08.05.2020 15:36 # 9
106_arts
I think the good price if it comes out in the service at that price
Get well soon
106_arts 2011-06-12 16:57:41
08.05.2020 15:36 # 10
dinoco
a special service where authorized service personnel come together and look at only pug and citroen .. I take it to him for years without blinking, I am sending him to my friends.
08.05.2020 15:36 # 11
get well soon bro ...
08.05.2020 15:36 # 12
Get well Dinocom Aman Attention .. Disapprove
08.05.2020 15:36 # 13
dinoco
Ersin and Colonel, thank you friends, mmmmmmmmmmmmm
08.05.2020 15:36 # 14
No, it is late.
What happened, the seal broke down ??? Did he do the heat? It should not be a light thing, as it hurts enough oil to leak under it ...
In addition, only the gasket replacement does not hold those numbers.
08.05.2020 15:36 # 15
Get well soon. What's in 350-400? Cylinder head gasket (for my vehicle) 30 TL 70 TL to get workmanship 100 TL. There are other things in it!
08.05.2020 15:36 # 16
axi206
I haven't seen the upper cover that didn't hurt until today
08.05.2020 15:36 # 17
It is good to detect and eliminate cancer before it grows.
respects
08.05.2020 15:36 # 18
dinoco
Thank you for your good wishes Kenan ..
I received the vehicle today, I paid 420 TL in total, it was much better than before :)
Within 420 TL
engine oil and filter
steering fluid
thick cartel sheet
There are cleanliness including internal and external engine.
wurt injector cleaner + peach flavored glass water concentrate.
Also, I had voice problems in the front team.
There was a sound coming from my boot and trunk lock. The lock was changed and the trapezoidal iron was completely covered with plastic hose, the trapezoidal areas were corrected, and the wash was installed and cleaned.
I love my service very much, the money they get is always halal for these guys :))
Dinoco 2011-06-14 23:24:48
08.05.2020 15:36 # 19
dinoco
I saw a lot of msgs, I am sorry. There is no heat. In my service, only the cylinder head hurts and the gasket change is 300 TL. the extra b, the rsure is also changed. I gave 420tl but I am satisfied. 100tlsi lower cartel protection sheet of it. or something ..
08.05.2020 15:36 # 20
As you said, let it be late
Page : / 2
