The engine will not start
08.05.2020 18:24 # 1
fahrettin
Hello friends
The other day, when I was driving on gas with my car, my gas decreased and I started to sing, I continued with gas. I could not start the car the next morning. I opened the ignition by holding the gas button to operate directly with gas, but it also did not work with gas. I guess it doesn't work because the gas is too little. In the evening, I bought gasoline with a canister and it didn't work again. Even though I put about 50-60 TL gasoline in total 3 bins, it still doesn't work.
As far as I learned, I may have damaged the gas pump by starting the car when the gas tank is empty. As I know the end of the month, I will have to wait next week to take it to the master. Does anyone have any idea what could be the cause of the malfunction?
08.05.2020 18:24 # 2
[QUOTE = fahrettin] Hello friends
the reason for the fault is hidden in your post
08.05.2020 18:24 # 3
fahrettin
[QUOTE = dogan106] [QUOTE = fahrettin] Hello friends
thank you LOL So let me change the question like this. Is there another practical solution to the malfunction that I do not know?
08.05.2020 18:24 # 4
CrimsonChild
hit me, teacher :) The same thing happened to me
08.05.2020 18:24 # 5
samet206
It looks like the gas pump is not another blessing. Leaving the tank empty will hit you until the results change :)
08.05.2020 18:24 # 6
pusutr
I think don't hit it. shame on the car. if possible, hold the vehicle downhill for a while, maybe petrol will switch to the engine and it will work.
Or learn how to get air in a gasoline vehicle and run it.
08.05.2020 18:24 # 7
fahrettin
[QUOTE = CrimsonChild] hit it hod :) I had the same thing I did, I hit the clip [/ QUOTE]
I tried to hit it, it didn't work with the hit. If it is already working with knock, does it not have to be operated by direct throttle?
08.05.2020 18:24 # 8
erdem-120
If you can reach the hose that makes the gasoline inlet to the engine, unplug it then turn the ignition on and off until gasoline comes out of the hose. If it comes anyway, if it doesn't work, pump should change.
08.05.2020 18:24 # 9
fahrettin
Guys, we fixed the problem. I called the master next to the car. We replaced the gas pump. It wasn't the first time, but by shaking the car, we ran the gas pump with a little poke. Materials + labor cost 180TL. I would never advise anyone to make the same mistake after that, never use the gasoline level below a quarter. Respect everyone
fahrettin 2014-03-31 10:44:53
08.05.2020 18:24 # 10
307Mster58
gasoline hose may be out, you can see that when you look at the back of the engine, it may be in the pump but as far as I can put gasoline in the bottle could hurt, but i think it is a superstition
08.05.2020 18:24 # 11
307Mster58
sorry problem i wanted to help so i became a member Smile
08.05.2020 18:24 # 12
fahrettin
[QUOTE = 307Mster58] sorry the problem was fixed I wanted to help so i became a member Smile [/ QUOTE]
Thank you, teacher. peugeotturkey has gained a new member LOL
