The engine was frozen, help me!
08.05.2020 19:35 # 1
Mehmetkrblt
Good evening, friends 307 1.6 gasoline LPG, I got into my car, I tried to run it all evening, it didn't sound like that, it didn't work like that, it didn't work again, it didn't work like plug, plug, plug, shot, I went down, I looked, then the pipes of the radio kept ice like snow. Today it was good, I looked at the pipes, I said, I said, I added the water in the pipes, the water of the radio, the water was reduced, I said, I tried to work again, it was like 10 or 10 seconds, it didn't work. What is going on?
08.05.2020 19:35 # 2
samet206
Wasn't there antifreeze in the vehicle? Or if you don't trust, I wish you hadn't opened the cover of the spare water canister and started the starter without looking at it for ice. There is not much to do anymore. no expense.
08.05.2020 19:35 # 3
Racon34
Brother, I hope there is nothing important, but you have made a huge mistake. This is a very important event.
08.05.2020 19:35 # 4
herry
In such cases, the radiator spare water cover will hurt and see if there is no freezing, there is no problem. Of course, one should not miss the antifreeze. Get well soon.
08.05.2020 19:35 # 5
IbRahiM_quRcaN
It comes to mind that the engine is gone, hopefully you can get over it
08.05.2020 19:35 # 6
fætih
There may be a situation from block cracking to the gasket. My father had frozen the vectra, nothing happened to God, we burned our stove in the industry in the shop for a day ...
08.05.2020 19:35 # 7
outlaw
I HAVE BREAKED THE BLOCK IN MALESEF AND PRICE 4000 TL 5 YEARS FIRST, THE CROSS ARGON SOURCE HAS NOT GUARANTEED IT ...
VERY LAST PAST ...
Confused
08.05.2020 19:35 # 8
okan77
My friend, be aware of such cases, the frozen engine is never started ... The reason is that the recirculation engine is running in the coolant. The circulating propellers in the frozen water cannot rotate and sounds as you hear ... The timing may break off, the propellers can be damaged, the block may break due to the frozen water. . Get well soon..
