the engine shoots stun, does not eat gas
08.05.2020 21:15 # 1
RECEPD
Hello friends;
My car started to hit the stump while the 307 xt model was moving on the 2004 model road and suddenly the temperature rose to the right, and today the coil has changed 25 km after making it, it is about to come home, the same problem has been repeated.
thanks in advance for your help
08.05.2020 21:15 # 2
First of all, welcome to us. vehicle diesel or gasoline lpg limi teacher. if lpg is available it is probably a lpg related situation. well, it changed in spark plugs when the coil was changing
08.05.2020 21:15 # 3
RECEPD
First of all, thanks for your quick return and your connection, my car lpg li coil was checked before changing the lpg, they said there was no problem, but the spark plugs did not change.
thanks..
08.05.2020 21:15 # 4
byrm7
Have the timing control checked as if it was toothed or there is a different problem (timing bearings eccentric gear)
