The engine runs until it heats up.
08.05.2020 19:12 # 1
koray.turan
Hello friends. My car runs with little noise until the engine warms up but there is no gram sound after warming as if the car does not start. What or what could be the reason. The oil was changed 3000 km. Ten oil conditions were made ten times and pressure was very good when the pad was made. Thank you from now
08.05.2020 19:12 # 2
koray.turan
08.05.2020 19:12 # 3
talip206
Mine is the same, I think it's normal. The cold engine always runs more vibratively and louder. Especially when the weather is below 15 degrees. In my opinion, no problem is normal
08.05.2020 19:12 # 4
madblueblacksea
Same in my diesel. This is not a problem if it gets hot. The engine adjusts the valve itself and it does this with oil pressure. There is no problem when the engine is warmed up and the oil is filled with propellants. If it does not cut the sound, there is a problem. Today, tomorrow, when I say "Look at it tomorrow", threw the pusher and seven lions a thousand liras
08.05.2020 19:12 # 5
koray.turan
It is over .. I wanted to ask there is no sound in my heat. Thank you.
08.05.2020 19:12 # 6
nirvana666
This is a normal situation regardless of the brand / model. Imagine even how easy and effortless the cars work in the summer, but in the winter it is always a problem / shake / shivering etc. It is completely seasonal.
08.05.2020 19:12 # 7
koray.turan
Thank you actually when you think about it
