The engine noise changes when I press the clutch.
08.05.2020 17:26 # 1
ahmet_bjk
Hello guys ...
& nbsp;
2009 model 1.6 hdi 308 at
When the vehicle is idling, the sound of the engine is different. & Nbsp;
When I press the clutch, the sound of the engine returns to normal and there is a strange sound. The sound is not loud and cannot be heard from inside the vehicle when the windows are closed.
Anybody faced this situation?
What is the problem?
08.05.2020 17:26 # 2
msk_sansal
I have the same issue
08.05.2020 17:26 # 3
volkanC2
I do not know how it is written, but it has a name like `` prisdirek ball '', it is due to the gap formed in it, my 106 has the same problem, there is an additional sound next to the engine sound, it stops when I press the clutch, I asked the master, he said that the problem was from him, he even told us that the scrap was removed this part turns in idle :) when we press the clutch, it stops and the gear is stopping inside, that sound disappears, this is the event. & nbsp;
08.05.2020 17:26 # 4
ahmet_bjk
Thank you ...
It is not something that needs to be intervened. Doesn't cause a problem, right?
08.05.2020 17:26 # 5
volkanC2
My master said that there is no problem, when I am going to change the pressure pad, I will have it done too, because it was a laborious job to be distributed completely and there was no need to hurry. if you have financial means, make sure you are comfortable but don't have to worry about it "Wink"
08.05.2020 17:26 # 6
selammedikal3434
First of all, my friend said it was over. Because it is necessary to distribute the gearbox to destroy that sound. / div>
I said if I didn't listen to my master and if I had it done :)
