the engine is running at idle, the needle is falling off
08.05.2020 17:26 # 1
ismailkaya
My friends have started to have problems in the engine lately, it usually happens in the evening when the lights are turned on, when the parking is turned on, the & nbsp; & nbsp; when I press and hold the fireplace, the cycle hand comes to zero and it turns back to the idle setting & nbsp; comes out & nbsp; & nbsp;
08.05.2020 17:26 # 2
Aziz
Idling engine is cleaned in service. Don't spray lining spray or something. The same happened in my 306 sedan. it was almost going to Stop every time I pause. If we clean it, it is said and passed. If it is not resolved, you may have to change.
There is another suggestion that I wrote as an experience.
08.05.2020 17:26 # 3
selammedikal3434
The same problem happened with me and the same events you mentioned were coming to print. I inserted the idler engine, cleaned it with a spray, but it was broken again after 2-3 weeks.
Now I am living worse. When I run the boiler 2, I don't understand the temperature but sometimes the problem is resolved.
I was surprised what to do. . The original idling engine is around 150. I think we can take it and wear it
