the engine does not work well on gasoline
08.05.2020 15:54 # 1
tugrahan
hello guys have been in trouble for a few weeks
I press the ignition in the morning, the vehicle is running, the idle rises as it will stop
idling starts to drop, even if I do not give gas, it stops, I give a few gases
but then the engine is running jerky, also when running jerky like this
a lot of suction sounds are heard from the filter
When you switch to lpg, the engine runs like a clock, shaking goes off and the suction sound is cut off at idle
lpg gas like vehicle oil, idling, no problem
I tried in gasoline in 1 gear, the car is hard to get off, I'm idle, I do not say that you are in a period of 4000 revolutions, but the car does not go when the gear is gone, it hardly lifts itself.
I wonder what the problem is
the tugrah 2011-07-28 00:39:06
08.05.2020 15:54 # 2
sercinho
Have a problem with the oxygen probe
08.05.2020 15:54 # 3
hakann83
Is the gas lamp burning?
08.05.2020 15:54 # 4
ALX
Your answer is here. A very common problem.
http://forum.peugeotturkey.com/forum_posts.asp?tıd=14741&kw=alx&pıd=226064&title=106-quick-benzinde-ilk-alma-sorunu#226064
08.05.2020 15:54 # 5
tugrahan
none of the engine lamp or fault light is on
alx's writing is actually very logical
08.05.2020 15:54 # 6
turan306xr
Hello ALX says it was correct yesterday I had the same problem as lpg. I've been trying to find this problem for 2 months. I wish it was solved yesterday, ALX would help me too.
