The door is not locked (I figured it out)
08.05.2020 20:43 # 1
Mehmet UYAR
Friends, there is one more location. If I lock the car with a central lock or contact, the right sliding door is not locked with my hand. Mehmet UYAR 2018-02-02 18:01:40
08.05.2020 20:43 # 2
x571
the mechanism of the door may be broken. It has the original part for 180 TL.
08.05.2020 20:43 # 3
Mehmet UYAR
It is possible to have a look
08.05.2020 20:43 # 4
As our teacher friend said, the keys that understand whether our peugeot's door is opening and closing are possibly broken in the lock or their sockets are oxidized.
08.05.2020 20:43 # 5
husem
It has to change. 180 TL for which original vehicle I bought 300 TL.
08.05.2020 20:43 # 6
[QUOTE = husem] I need to change.180 TL for which original car I bought 300 TL. [/ QUOTE]
Unfortunately, the 206's is a bit expensive for the partner
08.05.2020 20:43 # 7
pusutr
This problem is eliminated if you cut the cable of the sensor, which senses that lock is open or closed, to the brain. You can do this too. I had it made for 20 TL per time. Now get 30 40 rubles.
08.05.2020 20:43 # 8
x571
[QUOTE = pusutr] This problem will be eliminated if you cut the cable of the sensor that senses that lock is open or closed. You can do this too. I had it made for 20 TL per time. Now get 30 40 rubles.
I have never tried. when he interferes with the cables, he never sees. Maybe the man who tried it had no ability. got to check. The cleanest thing is to change the mechanism. Cutting and cutting work sometimes cause other errors.
08.05.2020 20:43 # 9
Mehmet UYAR
My guess is that there is no problem with the lock.
08.05.2020 20:43 # 10
Mehmet UYAR
Friends, after a long time, I dismantled the plastic trim of the door, I observed the lock mechanism and observed it, and when I pressed the central lock, I saw that the engine was working, there was a connection wire between the engine and the lock.
08.05.2020 20:43 # 11
HasGur
[QUOTE = Mehmet UYAR] Friends, I dismantled the plastic floor of the door after a long time, I exposed and observed the locking mechanism and I saw that the engine was working when I pressed the central lock, there was a connection wire between the motor and the lock. ]
Get well soon ... Working for the automotive manufacturer within the scope of high-cost R&D studies Your problem is over without cutting the "o" cable, which is seen as unnecessary, that many engineers cannot calculate!
08.05.2020 20:43 # 12
Mehmet UYAR
Thank you, sometimes it is useful to look for the solutions ourselves, or as you said, I could be from that cable.
