The difference between the two products
08.05.2020 21:11 # 1
x571
1- I bought a product that was sold with the original label for coil replacement. but there is a big difference between the product that comes out of the vehicle and the product I bought as the original Is it normal to have so much difference? The product I bought may not be original? how do we understand its originality and where do we inquire?
yellow product coming out of the vehicle
new received with original tag
2- I noticed something I had not noticed before. When the vehicle worked at idle for 5 minutes after the change, water started to come out of the exhaust. drop by drop of gas with rain drops like rain. why does this happen? I smelled the liquid with my hand, there is no obvious bad smell. There is no oil or water lost in the engine.
08.05.2020 21:11 # 2
talip206
If you bought it by giving the sachet number, I don't think it will be a problem. Sometimes companies can go into minor revisions. Normally I changed 2 to 3 coils. It was all like what was on your vehicle.
The product you received looks original.
It is normal for the engine to drop water when it is cold. If the front of the vehicle looks a little uphill, it becomes more obvious that it throws water.
08.05.2020 21:11 # 3
x571
[QUOTE = talip206] I do not think there will be a problem if you have received the sachet number. Sometimes companies can go into minor revisions. Normally I changed 2 to 3 coils. It was all like what was on your vehicle.
It was like a yellow one. Was it like the yellow ones that you put on later? appears in photos. that yellow space is a tiny thing when i pick it up later, does it cause trouble in firing?
x571 2019-03-24 13:30:20
08.05.2020 21:11 # 4
talip206
Yeah it was like the yellow one. But it wasn't that yellow, it was like copper. The difference of the piece you bought later is that it has a hole in the middle. There was no such hole when I bought it. But I don't think it will be a problem. If it doesn't make misfire anyway, it means there is no problem.
08.05.2020 21:11 # 5
x571
[QUOTE = talip206] Yes, it was like the yellow one. But it wasn't that yellow, it was like copper. The difference of the piece you bought later is that it has a hole in the middle. There was no such hole when I bought it. But I don't think it will be a problem. If it doesn't misfire anyway, it means there is no problem. [/ QUOTE]
I wouldn't mind. He officially slid the shine of the car. I will return it tomorrow. We got it by supposedly providing the chassis number.
