the control does not work.
08.05.2020 15:49 # 1
alikocer
Sa 2001 206 I made a new key of my car. Of course without control. The door in the old key locks the doors again while locking. I press it once, closing the locks and opening them again. I lock it with the key. How can I fix my controller?
08.05.2020 15:49 # 2
You must fill in your profile information first so that we can help you.
08.05.2020 15:49 # 3
alikocer
What do you want my profile full? what does that have to do with my question? .........
08.05.2020 15:49 # 4
If I don't understand it wrong, the new key you have made has nothing to do with this event. Does it hurt when your car locked from your old remote?
08.05.2020 15:49 # 5
alikocer
Yeah, the new controller has nothing to do. I removed the inside of the old controller and put it back. The problem is that the old remote control also locks at the same time.
08.05.2020 15:49 # 6
EmRe26
Are you sure all doors and trunk are fully closed? If it is not fully closed, it does it the same way, but if it is closed, I would not know :(
08.05.2020 15:49 # 7
Probably a door stays open, or the key that checks if it is open is broken or there is a wiring in its wires. So you closed it awkwardly and it didn't work again?
08.05.2020 15:49 # 8
alikocer
[QUOTE = koliva] Probably a door stays open or the key is checked to see if it is open, or its cables are wrecked. So you closed it awkwardly and it didn't work again?
Thanks sometimes, the interior roof lamp is blinking open even when the doors are closed. probably the problem with the door sensors.
08.05.2020 15:49 # 9
[QUOTE = alikocer] [QUOTE = koliva] Probably a door stays open or the key is broken, which checks whether it is open, or its cables are wrecked. So you closed it awkwardly and it didn't work again?
Thanks sometimes, the interior roof lamp is blinking open even when the doors are closed. I guess the problem is in the door sensors. [/ QUOTE]
So it is definitely one of the door sensors.
08.05.2020 15:49 # 10
metin
Koliva doesn't lock with the key then, right? your friend is locked with the key
08.05.2020 15:49 # 11
bitli__pire
dude the same problem happened in my car. not related to the control is related to the door lock mechanism.
08.05.2020 15:49 # 12
alikocer
BENCEDE has no locks, but no bull here.
08.05.2020 15:49 # 13
Our sponsor will help you if you contact Cıkmacı Efe. No trouble at the point of going out
