The click from the timing
08.05.2020 19:29 # 1
cnrars
Guys, I just changed the timing set of my vehicle, timing set, recirculation etc.
It takes 2-3 days to change, but since that day, it comes with the moderate chic you know from the engine.
I showed it, they said it was because it was very nervous, they did something, they said it happened, it was less when the engine was hot, I didn't realize it at that moment, then I realized it, but it didn't improve, especially when the engine was cold, it shows the gap even from 50 meters away, that's why, how to fix it What should I do?
By the way my car is 207hdi, 1.6 90 hp.
08.05.2020 19:29 # 2
First of all, I think they have checked the sente setting. valves may hit the pistons. The master does a good check, after all, not free. we guess according to what you say. But definitely pressurize the master until that sound disappears, then the crime of a big breakdown will tell you that the attacks are already worn out.
08.05.2020 19:29 # 3
cnrars
[QUOTE = sonerkyl] I think my teacher first checked the sente setting to get past. valves may hit the pistons. The master does a good check, after all, not free. we guess according to what you say. But definitely pressurize the master until that sound disappears, then the crime of a big breakdown will tell you that the attacks are already old or something. [/ QUOTE]
Hi soner, thank you for your answer, what is the sente setting? Is this riddle about him? vehicle traction etc. It's okay, it's just fine with the engine running, and the obvious sound comes from the inside, and the outside sounds too much, like the bike chain sound you know, every time it rotates, it comes stylishly every millisecond.
08.05.2020 19:29 # 4
teacher, when you press and pull the gas, is there any increase or decrease in the sound. or a steady voice.
08.05.2020 19:29 # 5
cnrars
[QUOTE = sonerkyl] teacher, when you press and pull the gas, is there any increase or decrease in the sound. or a steady voice. [/ QUOTE]
there is a constant sound, especially in idling,
08.05.2020 19:29 # 6
Leprek0n
I do not know if it will be related to the subject, when I give the gas in my car, there is a buzzing sound like coming from the institutions inside the middle muffler. But it has nothing to do with the exhaust system. It comes from under the engine. (1.6 Thp Allure)
08.05.2020 19:29 # 7
Well, my teacher, show him as soon as possible, the master or the teacher did not screw something they removed, it may even be related to the pulleys, so it is difficult to say something without seeing it but in a way that will make it a master. Incorrect assembly related to the sentence adjustment timing set goes to the lock of the engine, no valve remains, the vehicle is bent, all in one, the circulation pump was replaced with the timing change
08.05.2020 19:29 # 8
cnrars
[QUOTE = sonerkyl] Well, my teacher, show him as soon as possible, the master or the teacher did not screw the thing they removed, it may even be about the pulleys, so it is difficult to say something without seeing it, but as I said, in a way that makes it a master. Incorrect assembly related to the sentence adjustment timing set goes to the lock of the engine, no valve is left, the vehicle is bent.
just like the circulation has changed.
08.05.2020 19:29 # 9
My teacher may have a problem with the parts attached, the master needs to disassemble and check again, then your head may hurt. It is important to mention whether the parts installed are the original sub-industry or the important sub-industry. I don't think you should get on that much and then your head may hurt.
08.05.2020 19:29 # 10
alihan59
HELLO I gave me 550 TL when I changed it as a set. How much did you make a shop from the industry?
08.05.2020 19:29 # 11
cnrars
Recirculation timing in the authorized service or something 880
