The car takes water 206 1.4
08.05.2020 21:07 # 1
Maze87
Hello friend, the right rear seat of my car is getting a mop part of the water is like a lake now 2 things caught my attention I took it as a photo which do you think is getting water right rear taillight is filled with water and another one is petrol pump ground plastic is very bad, it is exactly like the flour. What is the name of the part?
08.05.2020 21:07 # 2
27BEN80
The masters answer, but I have followed the hurt issues before, and I know that the wicks of the stop lamps should change.
08.05.2020 21:07 # 3
Maze87
I wonder if I pull it out or change it directly.
08.05.2020 21:07 # 4
husobay
hello full stop with a very fine drill bit from the bottom
you can make a gentle hole and let the water drain
Good luck with
08.05.2020 21:07 # 5
the gasoline tank door does not enter the surroundings, teacher water problem probably the interior insulation of the door - drain channel and wicks have a stop lamp sponge that may be worn out.
08.05.2020 21:07 # 6
Maze87
Thank you for the answers, I will check all of them and do what is necessary. What is the name of the petrol pump inlet, which you see in this photo, exactly, I want to get that black plastic place zero and change it.
08.05.2020 21:07 # 7
sezar206
No water coming from the stop or tank. Have the door wick checked. Make sure to stop it, but it is not good if it does not get water
