the car is removing water and the front rear mop is wet?
08.05.2020 20:13 # 1
ziya alp
friends, the car is decreasing water, and the left and left back wet inn is very wet, it becomes lake, sometimes it is moist, why does it come to the media? alpine 2017-03-05 17:01:43
08.05.2020 20:13 # 2
My teacher is missing the radiator from the gaskets
08.05.2020 20:13 # 3
ziya alp
how much does it cost? This product is a bidet.
08.05.2020 20:13 # 4
If you find a good master from the gasket if there is a drop in water, the master who does not know 50-60 TL will be inserted, says the price from 350-400.
08.05.2020 20:13 # 5
ziya alp
When you come out of the pocket, you can throw a link, where to do, etc.
08.05.2020 20:13 # 6
I did it myself because if it works like this, it will cost you 5-6 TL, 5 lire liquid gasket, 1 TL, 2 orşng :) link
08.05.2020 20:13 # 7
samet206
Get well. I think the problem of classic heater core. I guess there is no one who has not experienced this problem in our vehicles.
08.05.2020 20:13 # 8
ziya alp
thank you soner brother i got the link i will show it to the master insallah can do :(
08.05.2020 20:13 # 9
Ahmetaltan
You may have missed the rate because you filled the antifreeze randomly. This causes leakage from the oring of the heater core. When I filled Antifreeze into my own car, it started leaking from the oring. When I had an antifreeze measurement (-30), it stopped. The leak was interrupted when I added some water and increased the water rate.
08.05.2020 20:13 # 10
Baran35
An auto electrician who has absorbed halal milk from his mother solves his problem if he is a radiator. I guess it doesn't even cost 40-50 lira if it's just missing from the gaskets. However, if the radiator will change, there is no dismantling or dismantling, but the cost is minimum 250 liras. 1 month ago I changed Kale brand radiators and 150 lira for 150 lira. Just like a radiator, it never started to blow in 2 weeks in icy weather. Now Izmir is at 20 degrees but started to work whatever my heater is. If there is no problem with my recommendation radiator, if the gaskets do not improve, you will do what I have to say. God bless you, I wish you trouble-free days.
08.05.2020 20:13 # 11
Baran35
[QUOTE = Ahmetaltan] You may have missed the rate because you filled the antifreeze randomly. This causes leakage from the oring of the heater core. When I filled Antifreeze into my own car, it started leaking from the oring. When I had an antifreeze measurement (-30), it stopped. The leak was interrupted when I added some water and increased the water rate. [/ QUOTE]
I mean the same had happened, so we changed the radiator in vain .. Oh these masters .....
08.05.2020 20:13 # 12
ziya alp
As Soner brother said, I was washing my car before the radiator, I was washing it, it was wet, I washed it, I took it dry, then I saw the water, there was a washer, we pulled it, then I saw it, glutier, then there was water, there was a cold in the engine, I looked at it, we had a taste of water, then we had a taste of it Let's take care of my radiator dad
08.05.2020 20:13 # 13
If he puts a dry cloth in the place that is seen in that picture, you will be able to do it yourself.
08.05.2020 20:13 # 14
ziya alp
I don't have a team swap, I haven't done anything like that. There is a familiar master. He finds us.
08.05.2020 20:13 # 15
Indeed, even if you make a master, you don't have to go to the boiler, if he is a good master, if he takes a look at the pictures and reads what is written, he should do the rest in 1-2 hours.
08.05.2020 20:13 # 16
ziya alp
soner brother left and sofor coming from the place where the water was there, did you enjoy the taste of your water, sugar antifreeze side
08.05.2020 20:13 # 17
it was just like my lake.
08.05.2020 20:13 # 18
ziya alp
my brother, I have the same goal, sometimes come back even when the water patch
08.05.2020 20:13 # 19
ziya alp
soner brother service 700 tl would jerk off the torpedoes in the industry he said he would be good, i found him to be good, i found him to be a master, i think i will bring him to him the problem of radiator peteg i was in the car, i have master in him i got him, i got him 106, i got him, i got him, he got him, he got him goturdu man now
08.05.2020 20:13 # 20
Generally it is from the gasket, but it is useful to have it checked when the honeycomb is removed, and then the other industries will be around 60 TL, but the valeo is a little expensive around 160-170 TL. sub-industries are troubled, I often heard a lot of problems such as not heating.
Page : / 2
