The car is not working
08.05.2020 21:17 # 1
sametagr
Hi guys first. My Peugeot 307 XR Automatic 2004 model car has not received a starter for the first time in 2 days and gives an error called "put auto transmission lever in position P". The vehicle is running after about 10 minutes of effort. If there is a friend like this, can it help? What is trouble?
08.05.2020 21:17 # 2
Cemm
[QUOTE = sametagr] Hello guys first. & Nbsp; My Peugeot 307 XR Auto 2004 model car hasn't been starting for 2 days since the first start, giving an error "put auto transmission lever in position P". The vehicle is running after about 10 minutes of effort. If there is a friend like this, can it help? What is the problem? [/ QUOTE]
If there is a sequential system in the vehicle, maybe your gas pump may be low in pressure, make sure the vehicle is in the park position. If you do not work, it can be enough to renew the spark plug for ignition then you can continue with the coil etc. etc. I believe that the problem will be solved when the brake sensor changes.
08.05.2020 21:17 # 3
sametagr
I guess, as you said, ask for brake trouble. Could it be caused by poor quality gas? The place where I bought the last fuel is not very reliable, I stopped by on the road.
08.05.2020 21:17 # 4
sozuak
Does the gear indicator show the park position? It should work in the P or N positions, but check the accuracy first, as the gear position switch is responsible for showing the correct position.
08.05.2020 21:17 # 5
Cemm
[QUOTE = sametagr] I guess, as you said, trouble with the brake mat. Well, it may have been caused by poor quality gas, where the last fuel I bought is not very reliable, I stopped by on the road. may need to be looked at but I don't think it will be too costly to have a good ride :)
08.05.2020 21:17 # 6
sametagr
Thank you for your help.
