THE CAR DOES NOT WORK !!
08.05.2020 19:32 # 1
R.CaVuS
Hello friends, I have a 2004 model 1.6 engine 307. Lpg is not installed in my vehicle. The car does not work when I try to start the car more than 12 hours later! But it works when I smell flammable things like gasoline, perfume. One of your friend said there might be a problem with the throat butterfly. Why this problem is caused. Urgent help ..
08.05.2020 19:32 # 2
Sir, petrol pump injectors. These are the first things that come to my mind
08.05.2020 19:32 # 3
R.CaVuS
[QUOTE = sonerkyl] Hodja gas pump injectors. These are the first things that come to my mind [/ QUOTE]
I suspect the gas pump, but even if the car does not start, when I turn on the ignition and start the engine, gas comes from the gas hose that enters the engine. I didn't understand that I'm sick of it. If I start the car again 2 hours after starting it, there is no problem, but if 12 hours pass, it does not work without smelling gasoline or perfume or something.
08.05.2020 19:32 # 4
Firtina61
I do not know if there is anything to do with brother, but our Ford connect vehicle had almost the same problem, it does not work when it is not running for a long time.
08.05.2020 19:32 # 5
jackalizm58
There is an emission sensor at the top of the air filter, if it is dirty or broken, it will not start, your vehicle will clean it with a lining spray and I will experience the same problem.
08.05.2020 19:32 # 6
jackalizm58
Don't be wrong on the pipe to the air filter
08.05.2020 19:32 # 7
R.CaVuS
[QUOTE = Storm61] I don't know if there is anything to do with brother, but our Ford connect vehicle had almost the same problem, it doesn't work after a long period of time.
As far as I know, there is no glow plug in gasoline vehicles.
08.05.2020 19:32 # 8
R.CaVuS
[QUOTE = jackalizm58] Wrong on the pipe to the air filter [/ QUOTE]
What kind of mistake?
08.05.2020 19:32 # 9
R.CaVuS
[QUOTE = jackalizm58] There is an emission sensor on the top of the air filter, if it is dirty or broken, it will not start, your vehicle will clean it with a lining spray and I have experienced the same problem [/ QUOTE]
How does that sensor have another name?
08.05.2020 19:32 # 10
jackalizm58
my teacher is on the top of the pipe that goes to diesel 307 air filter in my vehicles, so it is inside the pipe, so there is already a cable connection in the pipe that cable is connected to the emission sensor
08.05.2020 19:32 # 11
R.CaVuS
[QUOTE = jackalizm58] my teacher is called emission sensor, in our vehicles, the diesel 307 is above the pipe that goes to the air filter, in other words, there is already a cable connection in the pipe, it is connected to the cable emission sensor
Doesn't the malfunction light come on if the distress is caused by this tool?
08.05.2020 19:32 # 12
R.CaVuS
actual
08.05.2020 19:32 # 13
jackalizm58
My master must light the malfunctioning lamp yes, but if your car is working when you smell flammable material, it makes it from the emission sensor, it makes it from the gas butterfly sensor, it does not burn the old gas plugs. or it may cause other places to deteriorate
08.05.2020 19:32 # 14
R.CaVuS
CURRENT EMERGENCY AID PLEASE DO NOT WORK WHEN THE CAR IS COOLED TODAY 10 times in the morning, but it does not work.
08.05.2020 19:32 # 15
yaman14
same problem is present in my car 2004 xt alpine white my car hit and run the car i'm going to auto electrician the car is working with mars yesterday i changed the spark plugs yesterday the same morning i started the starter nobody where do you smell my perfume to the car ..
08.05.2020 19:32 # 16
R.CaVuS
Squeeze a little amount into the air hose, ie the air comes out of the point where the flow meter connects, and squeeze it into the hose.
08.05.2020 19:32 # 17
yaman14
problem solved in my car 2004 1.6 xt
The grank sensor was faulty.
would make this malfunction for 2 reasons
1 grank sensor
2 heat sensors are important to the master you go to
they would start from my battery
starter motor
spark plugs
He said he would go to the fuse box, thank you master .. he told me call me back said man
