The car does not lock: / EMERGENCY AID (Resolved)
08.05.2020 18:06 # 1
kursat3006
Good evening, dear friends! If I can't fix this, I will be crazy. Doors locked with neither control nor key.
When I enter a ditch or go through the car, the overhead lamp gives an open door warning. When I tried to close it later, the locks were closed and it was urgent again.
But I couldn't lock the door today, even though I did the same thing. I said that the last resort is locked with a key.
I think there is a problem with the sensors, what can I do at the back door please helpnnnnnn
kursat3006 2014-03-26 01:28:31
08.05.2020 18:06 # 2
Serkan
First, clean the sensors with the w40, wrap a little tape (in the form of a small cylinder) where the door locks are seated. If not, you need to change it again, wd40 tighten the door lock.
08.05.2020 18:06 # 3
kursat3006
Where exactly are the sensors serkan abi?
08.05.2020 18:06 # 4
Serkan
On the lock you can clean the locks beautifully
08.05.2020 18:06 # 5
kursat3006
okay serkan brother tomorrow morning i get a wd-40 from the first gas station i saw ..
health to your keyboard Clap
08.05.2020 18:06 # 6
yavuz_0051
If you solve the same problem, let me know in the summer.
08.05.2020 18:06 # 7
volkanC2
It is necessary to open and close the car with a key once in a while that if the control does not work, we can operate with the key, otherwise it is very difficult to lock it with the key.
08.05.2020 18:06 # 8
kursat3006
My brother doesn't get locked with this key too: key
08.05.2020 18:06 # 9
volkanC2
Not hard enough to break but hard enough to spin? Maybe it has never been opened with the key since it was received :)
08.05.2020 18:06 # 10
kursat3006
Lazy lion :)
08.05.2020 18:06 # 11
kursat3006
Friends today, I bought another brand of wd 40 variant, I bored, the problem was not solved again .. I had the tape attached to the iron in the place where the bonnet was locked and thickened it again :( industrial roads appeared again to us
08.05.2020 18:06 # 12
If the spare key of the vehicle stops, try to open it with the door.
08.05.2020 18:06 # 13
kursat3006
Unfortunately, no
08.05.2020 18:06 # 14
C@GL@R
I changed it from the sensor, there is no 200-250 repairs ...
08.05.2020 18:06 # 15
pusutr
I had the same problem for my left door. I was constantly receiving the left door open warning and had to lock the doors from the inside.
To do this, I first pressed the pad lining cleaner on the door lock. After a while, I squeezed thin oil. Then I take off the interior trim and tightened the socket to the door. Fortunately, there was no such problem after that.
I think it has been about 5 months since we did this.
08.05.2020 18:06 # 16
kursat3006
200 250 MI well I will close it all inside :) wd 40 did not fix it, but it was a disassembling experience .. Thanks friends
08.05.2020 18:06 # 17
Serkan
Disassemble and try and see if it is not a bidet, unfortunately it will change.
08.05.2020 18:06 # 18
kursat3006
I came home from school just a little while trying to close the doors from inside, I realized that I did not screw the wd 40 with the black plastic hose (I do not know the name).
08.05.2020 18:06 # 19
ahmed206
Did WD40 solve the whole problem ???
Could you take a picture of this piece please :)
08.05.2020 18:06 # 20
muratozhal
eveett i have the same problem i am waiting excitedly :)
Page : / 3
