The buzzing when turning right
08.05.2020 18:15 # 1
yenice
Hello. a humming sound comes from the front while making the steering half right. same situation does not turn left. what kind of trouble can it be? At first, I thought it might be winter tires, but I thought it wasn't because it wasn't turning to the left.
08.05.2020 18:15 # 2
kivanc
They can be made of a winter tire. There is a hum on my way.
08.05.2020 18:15 # 3
herry
[QUOTE = newish] Hello. a humming sound comes from the front while making the steering half right. same situation does not turn left. what kind of trouble can it be? At first, I thought it might be winter tires, but I thought it wasn't because it wasn't turning to the left.
Is there a sports spring?
08.05.2020 18:15 # 4
the pore ball is about to disperse. Have it checked urgently.
08.05.2020 18:15 # 5
muku
may fume into the hood
08.05.2020 18:15 # 6
captain_b5
If the sound increases when you accelerate, it is probably from the bearing (wheel).
08.05.2020 18:15 # 7
yenice
There is no such sound when I accelerate or turn left. it comes only when turning right. yes there is a sports bow. And what do you call this hub ball?
08.05.2020 18:15 # 8
The weaving where the rim and disc sit is in the full core of the part. The fault you describe is the hub ball. The same did not happen to me when accelerating or decelerating or freezing to the left, but when I froze to the right, snoring was a snoring snoring sound. Right wheel has changed.
08.05.2020 18:15 # 9
captain_b5
I had the same problem, I changed the left wheel ball last month. When I was speeding, I said wrong. When you turn the steering wheel to the side that makes the sound at high speeds (120filan), the sound should come much more.
08.05.2020 18:15 # 10
yenice
Since the speed is 120, I can not understand since I have no chance to make the steering half-right. But today I tried something, I made the steering wheel right and back and forth in a vacant area, there is no sound when going back, there is a buzzing caused by rubbing like you say when going forward. Actually, we can say that it is not humming but full rubbing sound. I have no chance to show until Saturday, I will be pleased if the friends who changed the ball change take time. thanks.
08.05.2020 18:15 # 11
ahmed206
Does it matter in gear or idle, and look at this.
08.05.2020 18:15 # 12
herry
The ball change does not take more than 1 hour.
08.05.2020 18:15 # 13
muhammed.ceyhan
hub ball? no axle ball?
08.05.2020 18:15 # 14
erman0464
I had the same problem, it was very clear on the right bends to the right. There was nothing going straight.
