The buzz rises while pressing the gas in 307
08.05.2020 16:01 # 1
kuantum
Sometimes at a low speed, sometimes at a high speed, but especially when pressing the gas, a hum comes up. Like the sound of the plane getting up. Or when the dynamo is attached to the bicycle wheels, that dynamo will sing in motion, like it. I got tor-balanced. I didn't get any results. I showed their pads, they said it was clean (though they couldn't convince me, because it would be squeaking to press the brake ..)
I'm not sure, but it may be coming from the wheels .. What might it be about?
08.05.2020 16:01 # 2
Does the sound come from the motor part?
08.05.2020 16:01 # 3
kuantum
I'm not sure, but it sounds like something is rubbing against something. As if coming from wheels rather than motor.
08.05.2020 16:01 # 4
According to our narration, the axle ball is going crazy, I say that you look at dreams
08.05.2020 16:01 # 5
metin
[QUOTE = koliva] Is the sound coming from the motor part?
vence from koliva gearbox (:
2006 Peugeot 307 SW 1.6 Comfort Triptonic Gear Gasoline + LPG (Make up case)
There are messages that the successor has problems with the transmission in other matters.
08.05.2020 16:01 # 6
kuantum
Does the transmission sound like this?
08.05.2020 16:01 # 7
kuantum
Also, could the throttle be contaminated at 60,000? does this sound when the part gets dirty, trouble in gearshifts, and shaking while idling?
08.05.2020 16:01 # 8
taksicicocuk
gentleman as a taxi driver, I come across with the failures that can be seen on a vehicle before anyone else since I have done 10000 km per month. according to this;
First, how many thousandth of your tires?
and what is the brand of your tires?
Also, has any device connected to your vehicle that could draw power from tape column navigation etc. battery?
Is the sound coming from the ship's room working like a whistling or is it like a whistling sound that comes as you press the gas?
I am also familiar with such troubles as I am a mechanic.
footnote: your pads are not finished, because your discs are thinner, place the middle but only a very light metal part remains on the edge and when it rubs there the sound will be heard.
Embarrassed
08.05.2020 16:01 # 9
taksicicocuk
If you buy the fuel especially from big companies like opet, why does it usually fail?
because there are many additives here. like fullforce aygaz euro lpg + mogaz not know
What if those who do not believe me at the moment are asking for emissions stamps,
08.05.2020 16:01 # 10
kuantum
[QUOTE = taksicicocuk] gentleman, as a taxi driver, I come across faults that can be seen on a vehicle before everyone else since I have done 10000 km per month. according to this;
I just bought the car, my tires are in good condition, but I don't remember the brand at the moment, frankly. the sound is a bit like a whistle. While getting up after taking off in big passenger buses, it usually sounds like this. you can even understand that the gear changes without fluctuating in that sound.
08.05.2020 16:01 # 11
metin
[QUOTE = quantum] and the car at 60,000, could the throttle be contaminated? Does this sound dirty when the part gets dirty, shaking gears and shaking while idling? [/ QUOTE]
the throttle pollution normal vehicle also has lpg,
There may be a problem in gear shifts; The gearbox is not separate like the manuals, it works with the engine, so the shaft inside rotates continuously, naturally lpg and petrol burning octane etc. are different, but the engine will fall out of normal operation even if you cannot feel it. It is affected by this because it works continuously with the engine in the transmission.
08.05.2020 16:01 # 12
taksicicocuk
Usually, hard rubber tire brands like bridgestone start making noise as they run out, but if your trouble is like in the bus, it may come from the flow balls, be careful.
08.05.2020 16:01 # 13
metin
[QUOTE = taksicicocuk] If you buy the fuel especially from big companies such as opet, why does it usually fail?
Which oil company do you recommend?
08.05.2020 16:01 # 14
kuantum
Considering the researches I have done from other websites, I have come to the conclusion that there may be a problem with the axle balls.
08.05.2020 16:01 # 15
I agree there is a problem with the diesel
08.05.2020 16:01 # 16
cermiki
As it is said, I bought diesel oil from Opet and gave a fuel error. I deleted the error in the service. However, after 2 weeks break, it started to malfunction again. Where did I go? I think it was congested. He's singing in the morning.
08.05.2020 16:01 # 17
kuantum
I changed the axle ball, but the sound continues.
08.05.2020 16:01 # 18
It would be nice if we could get a video.
08.05.2020 16:01 # 19
I personally take the fuel from opet or shell. Today, I looked at my emission value, I bought exhaust stamps, all values are normal. The setting writes perfectly.
08.05.2020 16:01 # 20
berk2309
my brother whistling style or turbo suction power sound like sound, the torque converter is about to go, especially when it is in 2nd gear, the pull of the car is low.
Page : / 2
