The buzz is coming from 206 engines.
08.05.2020 14:55 # 1
BERKAN
hello 2005 model 206 hdı have xdesing. There is a problem in my car until about 3000 rpm, there is a fine sound, it buzzes, but after 3000 rpm, that sound disappears.
08.05.2020 14:55 # 2
Oh my brother, I opened the same topic the other day, but there was no answer.
08.05.2020 14:55 # 3
I was going to show it somewhere but I know what I said, the guys are normal but I want to have it checked anyway
08.05.2020 14:55 # 4
elnino35
Normally, the valve settings are bad. I probably got it done today. Very tight valves cause it to burn too much gas.
08.05.2020 14:55 # 5
[QUOTE = elnino35] normal but the valve settings are bad, probably I got it done today too tight valve will cause you to burn a lot of gasoline, I think go right now [/ QUOTE]
Dad, you are more than right, the fuel situation has changed for the last few years ... as if it started to burn more ... so where can we help you?
08.05.2020 14:55 # 6
actual
08.05.2020 14:55 # 7
Onur
sounds sound creaking? so it can be from the valve setting
08.05.2020 14:55 # 8
BERKAN
but the interesting part is that it cuts after a certain cycle. It sounds like a tiny little sound, then the speed rises when it reaches a certain level. thank you to those who are trying to help in the meantime ..
08.05.2020 14:55 # 9
elnino35
There were places to recommend if you were in Izmir, but you can get something around 30 to 40 lira from any place that repairs the engine.
