The buzz from the right side of the vehicle ...
08.05.2020 19:49 # 1
Dem40
SA Peugeot family. I joined you with a 2007 model 307. I like my car but the sound of those doors closing is a little bad. So it is for such a car ... I love my car diesel and the tow, but there is a problem:
After I bought the car, I wanted to change the oil and filters and feel comfortable. I went to the most expensive master in where I was and the process is done. Only after the oil, diesel filter and other filters changed, a buzzing sound started to come from the right side of the vehicle. When I go, it is slow when it slows down and stops ... I went to the master, this voice says normal. He worked late while working today. This sound seems to fluctuate while turning the steering wheel ... The vehicle stopped today and the engine stopped, but the sound continues to sound ... Can this be related to the action taken? There is no place where I specialize on peugeot. After the oil change, the engine failed light. Imagine that the man couldn't find the place to connect the computer to get rid of ... What to do? Dem40 2016-05-30 02:32:46
08.05.2020 19:49 # 2
Eyup B.
It is not the most expensive master, as a workmanship :) I recommend you go to another master. Good luck by the way. I have 2010 206+ and my doors are closing like brodwey. Bidet is making a lot of noise in these pejoes.
08.05.2020 19:49 # 3
Dem40
:) Exactly ... In fact, I would go without thinking about the authorized service but ... I will say whether this sound has anything to do with the process. He will say no. Net ... :) Dem40 2016-05-30 10:55:16
08.05.2020 19:49 # 4
GokhaN
If the filters have changed, there is something else in your vehicle that can only be related to the sound you said with the oil.
08.05.2020 19:49 # 5
Dem40
Especially the diesel filter has forced too much. He could not find his place, then he tried and then he removed a piece of the foot. When the sound came close to the right from that side and started after this job, I ate it too. Maybe it has nothing to do as you say. It is cut off as it goes, especially when it stops. Like fan sound ... Dem40 2016-05-30 12:24:37
08.05.2020 19:49 # 6
GokhaN
if he did not find a master, he played with other things and broke them Smile
08.05.2020 19:49 # 7
Dem40
Do not ask ... It is highly likely that it was our job. Oh, sound like this fan. You start when you stop ...
08.05.2020 19:49 # 8
bariszeynep
I think the headlight engine may run constantly and make a lot of noise when it breaks down.
08.05.2020 19:49 # 9
Dem40
I got in the car today. Starts but does not work. Never before 2. I didn't even start. It worked a lot. When he finally worked, I took him to the master to ask the voice. The voice said normal. The sound fluctuates when you turn the steering wheel. "Look at the steering oil," I said. It was below the minimum. I had it added ... To the working event, it can be from the diesel filter, if we change again, he said. Let's see ... Then I asked the voice for a few more places. Is there any truth? Do you have a soft voice worker?
08.05.2020 19:49 # 10
ismailkaya
steering pump cranes. Increases or decreases when turning the steering wheel
08.05.2020 19:49 # 11
Dem40
I see ... So this sound event like that. So there is nothing to do. I have read in a forum that this voice can be reduced to an authorized service. I'll ask if my path falls.
08.05.2020 19:49 # 12
antyakn
Yav friends my vehicle 206 2000 model xr. Started a few days ago, when turning this steering wheel or driving in low gear, the sound of guacurt sounds, but not like the sound of iron, as if something is rubbing the vehicle. I took the vehicle to the industry, the right axle changed the ball, while I was going, I had the routine maintenance of the bidet. We changed the oil and water filters to flan. the voice still continues. I'll call the master again and see what kind of solution we'll find. When I get in the car, my ear goes to that sound, I can't even open music
08.05.2020 19:49 # 13
KRATERYA
People who suffer from door sound in passat forums when it comes to door sound is called chronic problem that has received 2015 passat Check the filters may be obsolete.
08.05.2020 19:49 # 14
JunioR56
My vehicle is 2003 307 xt. That fan sound got better when I pressed the pole head and the car continued to work when the ignition was switched on. Also, sometimes the entire system of the vehicle was deactivated in me. I noticed that the pole head was loose, and when it was tightened, it improved as if I did a magic touch. maybe it will help you.
08.05.2020 19:49 # 15
Dem40
[QUOTE = JunioR56] My car is 2003 307 xt. That fan sound got better when I pressed the pole head and the car continued to work when the ignition was switched on. Also, sometimes the entire system of the vehicle was deactivated in me. I noticed that the pole head was loose, and when it was tightened, it improved as if I did a magic touch. maybe it will help you. [/ QUOTE]
This is exactly my event. I will try my first job tomorrow. This sound looks like a fan, though not a fan. It is good to try. Thanks...
08.05.2020 19:49 # 16
pusutr
[QUOTE = antyakn] dear friends my car 206 xr model 2000. Started a few days ago, when turning this steering wheel or driving in low gear, the sound of guacurt sounds, but not like the sound of iron, as if something is rubbing the vehicle. I took the vehicle to the industry, the right axle changed the ball, while I was going, I had the routine maintenance of the bidet. We changed the oil and water filters to flan. the voice still continues. I'll call the master again and see what kind of solution we'll find. when I get in the car my ear goes to that sound I can't even open music [/ QUOTE]
Your slides need to change.
Even if there is no gap in the swings, dust and dirt are filled in as the bellows are torn and the sound you are calling starts to emerge.
I had the same problem last week, it improved when the swings changed.
there is someone in your moment and when that voice says what, one feels humiliated: D
08.05.2020 19:49 # 17
JunioR56
NOT AT ALL. WHAT IF WE COULD HELP. OBJECTIVE: NOT TO RECEIVE UNDERROWED COINS TO NEEDLESS MASTERS. WE DO NOT COLLECT FROM THE WAYS MALESEF.
IS YOUR PROBLEM CORRECTED? CAN I LEARN WHAT YOU DO?
08.05.2020 19:49 # 18
lamazibici06
problem solved
