The brightness of the brake light in the stop lamp does not increase. |
| 08.05.2020 20:59 | # 1 |
Make-up stop is attached to my vehicle. When I applied the brake for a while, the 3rd top on the top burns, but the brightness in the rear stops does not increase. The signal is in normal state (when the brake is not applied) and the reversing light is working without problems. I dismantled the vehicle's stops, there are 3 bulbs inside. (signal, reversing and brake light bulbs) these work smoothly. The problem can cause, how can I solve it.
| 08.05.2020 20:59 | # 2 |
The brake light bulb installed is not a double socket?
| 08.05.2020 20:59 | # 3 |
I know it is a double hear, it has two different points
| 08.05.2020 20:59 | # 4 |
okay then your trouble brake brake
| 08.05.2020 20:59 | # 5 |
If the brake sensor is not faulty, you have to make sure that the lamps are correctly installed. When the double socket lamps are inserted upside down, the lamps light up when the bright brake is pressed. So it's the opposite of what it should be
| 08.05.2020 20:59 | # 6 |
If your bulbs burst, the parking lamp lights up, but if the brake does not increase, the brightness bulb will burst.
| 08.05.2020 20:59 | # 7 |
When the brake sensor fails, the 3rd lamp on the trunk does not light up, so it has always been like this when the customer is malfunctioned. When the filament has a double filament, one shines normally, the other shines when the brake is pressed, the part that needs to shine loses this function. |
