The brake lining
08.05.2020 20:58 # 1
Maze87
Hello everyone, I went on holiday last week, my car pejo 206 xline 2004 model Antalya went on holiday while going downhill on the beach, the brakes did not officially hold, and the smoke started to rise from the front, I wanted to stop the car with a speed of 20-30 km, I could stop after 15-20 meters, I am braking. It got stiff then stopped, I pulled the handbrake, it was slightly downhill, not so much, the car did not even hold the handbrake, it continued to go slightly after it stopped, then we put stones under it, it stopped, I had maintenance, it changed to the front pad before I left, and I changed the rear drums, the car is not absent anyway, I think I got really thoroughly again. Let me show it to the master, or in some places they say it is normal, they say it is normal, I also went on a dirt road, I went up a hill for 20 km, then I went straight on the straight road, there is a whistling sound from the left wheel. Confused Maze87 2018-07-22 21:51:59
08.05.2020 20:58 # 2
Selcuk55
Now the first one is not getting the brake efficiency you want without changing the burnt blades. Since they removed it, most of the pads have been crowding mustache, you probably put it on the cheap pad. WinkLOL
08.05.2020 20:58 # 3
Aykut 28
Whether it is broken, my brother or the brake pads do not keep a certain distance after the change, so I do not mean that you do not hold, but if you stop for a little night, the pedal has seized it, I think that when you press it hard, Selcuk is your friend, you burned the gobi pad, I think it could have seen a direct master without doing anything. I say
08.05.2020 20:58 # 4
Maze87
yes, unfortunately I used a little bit of brakes then the way of the mechanic appeared again thank you
08.05.2020 20:58 # 5
Maze87
[QUOTE = Selçuk55] Now the first one is not getting the brake efficiency you want without changing the burnt of the pads. There was a carcinogenic substance in it. Since they removed it, most of the linings were singing a little bit of mustache, you probably put it in your car. WinkLOL [/ QUOTE] I did not put it all, I did not even ask for the master to do it, even I did not ask the brand or something. Maze87 2018-07-23 01:38:31
08.05.2020 20:58 # 6
Aykut 28
Let it be over again, brother.
08.05.2020 20:58 # 7
Maze87
thank you
