the bottom of the drive mat is wet |
| 08.05.2020 19:01 | # 1 |
| 08.05.2020 19:01 | # 2 |
muro_60 |
If you examine the form, there are a lot of topics about it. you will find the solution from there
| 08.05.2020 19:01 | # 3 |
Sertan |
Hodja, I opened a new subject. I would like to have a look at your heater core
| 08.05.2020 19:01 | # 4 |
Faruk |
[QUOTE = gungor] friends driver, do you have anything that happens to the bottom of the mat constantly wet 307 xt [/ QUOTE] Get well soon. 2007 also happened to me in 307 sw.
first the expenses were cleared but not over. then it turned out that when the vehicle was 8 years old, there was a fabrication error on the original windshield and the glass was removed and reinstalled. If your wetness comes to your head when it rains, it may be a problem like mine. |
| 08.05.2020 19:01 | # 5 |
not on both sides only the driver's side and the other sides were dry was yours only one side
| 08.05.2020 19:01 | # 6 |
Faruk |
In mine, only the driver's side was wet in rainy weather. he entered the windshield and dropped onto the brake pedal and was dripping into the lake. He kept water with the hose, and the service and location detected the problem. |
| 08.05.2020 19:01 | # 7 |
byderebey |
Most likely it is the heater core. It is possible to change the comb without dismantling the console. If possible, have it repaired or get the original price of 350 TL. I had the same last week. |
| 08.05.2020 19:01 | # 8 |
Heater core or gaskets have incontinence if there is no other leak in the sunroff or wet area. |
| 08.05.2020 19:01 | # 9 |
the problem was in the heater core gaskets
| 08.05.2020 19:01 | # 10 |
Well, my brother, I had the heater honey in my head right now. There was nothing. Someone said, there are tabs under the seats, one of them may have fallen. But the water filled into the marshmallows the other day, and I drained it, I think it happened after that. Probably there is an openness left and I say you have it checked. They even said that the rear headlight could come from there. I wrote what I heard, certainly I couldn't reach the solution yet I have the same problem.
| 08.05.2020 19:01 | # 11 |
THERE IS A LEAK ON THE HEATER
| 08.05.2020 19:01 | # 12 |
sonerkyl |
[QUOTE = lamazibici06] HEAT EXCHANGE IS IN THE HEATER [/ QUOTE] Capitalization is forbidden by forum rules, please note. good forums.
