The best LPG kit for 206
08.05.2020 18:27 # 1
ahmed206
Hello.
I am trying to find the most suitable LPG kit for my 1.4 gasoline 8v vehicle.
My request is for you to write your own kits with the plus and minus here.
I would also conduct a poll if it was authorized (announced to admins). Smile
Please get involved in this thread.
I want to have a system that does not light up the malfunction lamp.
Kit name .....
ahmed206 2014-04-13 01:12:08
08.05.2020 18:27 # 2
berkayakulker
I used it in 3 different vehicles.
2001 Fiat marea 1.6 sx
1997 Ford fiesta 1.25 ghia
1999 Peugeot 206 2.0 gti
08.05.2020 18:27 # 3
osmntskn
Sir, I wore lovato. The harmony is super smallest, no flickering and falling from the cycle. it's okay to take a ramp here.
The long road has not exceeded 20 cents until now, with an average speed of 100-120.
the only shortcoming is the problem of falling gasoline needle, its solution is in the forum. I couldn't find time and do it.
osmntskn 2014-04-13 09:39:00
08.05.2020 18:27 # 4
elsoberano
We used it in our scarce mtm 2 vehicle and I use it in my car.
08.05.2020 18:27 # 5
C@GL@R
anybody make lpg kit instead of spare tire
08.05.2020 18:27 # 6
ahmed206
None of the aforementioned burns a malfunction lamp? So what are the ones that light up the malfunction lamp?
In terms of service network, I will turn to the kits that can be in our region. Lovato, Atiker, BRC, Omevela (OMVL) ...
08.05.2020 18:27 # 7
KenBlockJR
[QUOTE = C @ GL @ R] friends have any lpg kit replaced by spare tire
Happening in the 307s
08.05.2020 18:27 # 8
Mesut48
I am very glad that I got the Lovato smartkit.
If you are on the road to Izmir, I have a place to recommend.
08.05.2020 18:27 # 9
Raskaa
I got my vehicle wrecked on the 206 + `` imma November 2013 '' with 1.4 engines and I am very pleased. It could be installed in the place of the spare tire (under the vehicle), but they asked for an additional 300 pounds for the protection plate and the larger tank, I got it installed from the 32-liter tank mounted in the trunk.
08.05.2020 18:27 # 10
Burak
I would recommend installing a lovato smart kit on my 106 vehicle, the technical support and warranty conditions of the lovato are very good
08.05.2020 18:27 # 11
ahmed206
So how much is Atiker Lovato and how much?
08.05.2020 18:27 # 12
ahmed206
Smart kit or OBD II for Lovato?
Fast, Nanofast, Microfast, Safefast or OBD II versions for Atiker?
Of course there is also the Atiker Gold kit. Which do you think?
I'm asking a lot of questions, sorry.
ahmed206 2014-04-14 00:11:23
08.05.2020 18:27 # 13
kursat3006
I will have the kit removed from scratch tomorrow (since I am not able to draw the project and invoice again because it is not about collecting and licensing). My two friends recently appreciated the Atiker micro fast, both of them are satisfied, and I will probably get the same one for 1000 TL. And the difference between fast and microfast is that micro's brain is smaller than fast. I write again Ahmet baba
08.05.2020 18:27 # 14
ahmed206
Summer pilgrim, I'm very pimpicikl about lpg.
Does anyone use Gold.
08.05.2020 18:27 # 15
Mesut48
[QUOTE = ahmed206] Smart kit or OBD II for Lovato?
Smart Kit. Takan master is important.
08.05.2020 18:27 # 16
furkanyakar
[/ QUOTE] I researched that job. He does not go through the examination in that way .. and he said that if the scuba lover loves me, I will give you his money. it was very dangerous ...
08.05.2020 18:27 # 17
kursat3006
As of today, I had a tube fitted on my already scuba car :) AKL powerfast. Tupcu familiar I insistently asked for microfast, and he forcibly put it on. Thanks to the difference in list prices, there is a 100 lira difference. This is an intellectual and software Italian other evening wiker production. The brand that atiker markets to Europe.
And when it comes to the obdli system, he said that it was absolutely not necessary, and that it was quite unnecessary in our vehicles. So I recommend. But that my unfortunate Bedouin continues. I said that the indicator was on the return, but the gas was over, I got a gax from it again, until it turned into a simulation. Sobra realized that when the hood opened, the gas hose to the brain came out. I called, I got rid of it, then I took care of it. So be careful, buuuuuum if the system doesn't cut the gas automatically.
08.05.2020 18:27 # 18
ahmed206
When these tubers know, they are very insistent.
I think our spare wheels are under the car (thank goodness I never used). Well, under the car, an lpg tank open to impacts and close to exhaust did not make sense to me either ...
Kürşat copy paste did you answer your aga Smile
08.05.2020 18:27 # 19
Serkan
I have a lovato smart installed, it was 8 thousand km, which was installed 14 thousand km ago, I have never had a malfunction lamp burned, the hot engine has the feature of starting with gas, the regulator is working directly with gas after the temperature exceeds 50 degrees. It does not consume gasoline during a short stop and start.
08.05.2020 18:27 # 20
kursat3006
[QUOTE = Serkan] I have lovato smart installed, 8 thousand km, which was installed 14 thousand km ago, I have no malfunction lights on me, the hot engine has the feature of starting with gas, the regulator is working directly with gas after the temperature exceeds 50 degrees. It does not consume gasoline during a short stop and start. [/ QUOTE]
The same feature is in my kit
Page : / 2
