The battery runs out to a halt.
08.05.2020 18:46 # 1
Hackerzade
First of all hello friends.2000 model 206 I have Roland Garros. The tachometer (km counter) of my car was defective and I had to replace it with a second hand part. when this happens at night, the battery is unnecessarily discharged. I have encountered this event twice. There was no such problem before. I think there is a problem in the new dashboard I have installed. Hackerzade 2014-08-22 23:28:01
08.05.2020 18:46 # 2
ank06sf940
easy to install, disassemble the old fault
08.05.2020 18:46 # 3
ank06sf940
I checked now if you are not ankara we will disassemble and try mine.
08.05.2020 18:46 # 4
samet206
there is no need to look for the problem away why it is obvious that if you do not have a problem like this before, a situation related to the panel you have attached does not have the authority to carry out such events alone, but things must be inspected.
08.05.2020 18:46 # 5
Hackerzade
I guess I probably applied to what the fuses are like and I am sure that there is a problem from the dashboard. After the examination, I can fix the problem by installing the old panel again, but I insist a little bit on this issue and I am looking for an idea to find and solve the problem.
