the battery is dead, we changed the battery, the vehicle is not working
08.05.2020 14:05 # 1
mesutakin
Hello; My vehicle is 2003 307 xt automatic. The vehicle did not start, we did battery reinforcement, the starter is pressing, the vehicle does not work. I took it to the private service, we connected it to the computer, the vehicle does not break down. The switch button light inside is blinking very quickly. Only my remote control key does not work due to malfunction, until this time I was operating with the normal key. I called the service, the brain did not read the reset key, they said that the brain would be connected to the computer and a new remote key would be ordered. I called any keymaker, the brain changed and they said that the key would be taught accordingly, and they say there was a cost of around 1,000 TL. A battery replacement is so costly I could not understand it or this vehicle will go to my service in case of a power failure. My vehicle is 18 thousand TL. vehicle battery in case of TL thousand. over charge. Is there a battery or something against the constant power cut in the brain? My friend says the battery, we changed the battery of a peugeot, the vehicle did not work, they did not call for service.
the mesutak 2009-08-10 12:57:17
08.05.2020 14:05 # 2
fatih1903
walla my car 307 xr 2003 triptonic the other day i said i will start the car i did not even start the starter did not even start the door, i couldn't even open the door with the remote control, then we looked at the battery, the plate was cut off, then it came out then we made up a battery, it worked fine, it is okay there is no problem, I did not understand why it did not make a problem .. :(
08.05.2020 14:05 # 3
deniz_206
It is interesting, but since I heard that the old chassis had a lot of electrical failure in the 307th, for example, the stop lamps were very malfunctioning.
08.05.2020 14:05 # 4
peugeotefe
if you reach me i will try to help
08.05.2020 14:05 # 5
Is the dingo's barn here?
If you introduce yourself, you will get more useful information about this topic.
Peugeot Forums - Peugeot Fan Club © 2025
FromOwner.co.uk — Buy & Sell Directly from Owners in the UK. No dealers. No commissions. Just from owners.
