The battery is dead, the doors cannot be opened
08.05.2020 19:34 # 1
106fb
My friends vehicle 2003 model 307.The battery is completely finished and the doors are not opening. What should I do?
08.05.2020 19:34 # 2
Mk307
Hodja, is there no key opening in the front driver's door? If there is, it opens from there
08.05.2020 19:34 # 3
106fb
There is, but I guess it doesn't open because the key is turned, but the central lock is there.
08.05.2020 19:34 # 4
samet206
Can't you open the doors manually? I did not fully understand the subject, but when you renew the battery, the controller wants my adaptation.
08.05.2020 19:34 # 5
106fb
The battery was weak. I had already started it with the help of reinforcement yesterday. But today I tried to open the remote control. It did not open the switch.
08.05.2020 19:34 # 6
samet206
The key opens master, you have a problem in the key part, maybe because you are always locked from the control, why not open it.
08.05.2020 19:34 # 7
106fb
yesterday, the battery was not pressed and I opened it with the key.
08.05.2020 19:34 # 8
talip206
If the driver's side does not open, try the door on the passenger side. it turns on manually with the key, even if the battery runs out normally
08.05.2020 19:34 # 9
106fb
There is no key opening on the passenger's side
08.05.2020 19:34 # 10
samet206
In the 307s, the driver door handle I know is just a key slot. In our 206s, the key slot on the right and the left is the friend.
08.05.2020 19:34 # 11
talip206
[QUOTE = samet206] In the 307s, the driver door handle I know as well has only the key slot on top of the door handle.
Yes, I thought like 206's. So sorry
08.05.2020 19:34 # 12
106fb
It protects and locks the locks in some brands of vehicles.
08.05.2020 19:34 # 13
Adem Kurtuldu
I guess it would be like that because we opened and closed directly without a battery, the central lock may not work electronically with the key, but when the key is opened, the manual is the worst driver's door.
08.05.2020 19:34 # 14
barishrocker
My battery was exhausted too, but the door was opening with the key, but I guess I couldn't lock the car because the central lock was disabled. I think I had locked the doors with the reinforcement, it remained in my mind. Replace the battery, take it right away and come up with 72 amps. barishrock is 2015-12-26 11:26:41
08.05.2020 19:34 # 15
106fb
If I can open the hood, I will change it already.
08.05.2020 19:34 # 16
barishrocker
I think you will have to sacrifice the butterfly glass :( but my doors were opened with the key, I remember well ..
08.05.2020 19:34 # 17
ahmet_bjk
Another one came to me too but the key turned a little hard and the doors were opened
08.05.2020 19:34 # 18
barishrocker
I guess mine sw yours hb Do you have a key in the trunk? Obviously, it opens the key or it is difficult to open because it is not used.
08.05.2020 19:34 # 19
sanctuary35
tighten the wd40 in the keyhole
