the antipollutio
08.05.2020 18:08 # 1
cansytnn
Good night..I will not stretch it too much. Can any of these 307s be able to solve the damn chronic Antipollution Faulty error, if any, how?
We took the board to the master without any error for 2 weeks, the turbo pressure said high, but actually covered the error for 2 weeks, I got the error again today.
08.05.2020 18:08 # 2
koramiral
translation = Antipollution Faulty I made a conclusion that something mechanical or electronic was dirty.
08.05.2020 18:08 # 3
cansytnn
If I say engine 0, the new output from the recipe has not yet filled 1500 km, I have made 900 km, after 600 km, all the oil filter or something will change, but I don't think it is from them, I think it is a different mistake because when the car passes 3000 cycles, the car throws black smoke in bulk and I get the error
08.05.2020 18:08 # 4
cansytnn
Is there no solution to this error?
08.05.2020 18:08 # 5
cansytnn
Is there no solution or this error?
08.05.2020 18:08 # 6
barishrocker
he gave me that fault. vehicle dropped from traction. I started to climb hard with 1st gear on the slope. When he said what was going on, he gave the error in a few hours. then I went to the service and connected the computer to the tool. A part called egr (or edr) failed. We tried to delete the fault and try again. then we changed this piece. the master said that he could still give the same fault and the brain should be repaired. then he fixed the brain and made no mistake again. There is no problem with traction at the moment. I hope that it will not come out ... the others are on you;)
08.05.2020 18:08 # 7
ahmet_bjk
[QUOTE = barishrocker] also gave me that malfunction. vehicle dropped from traction. I started to climb hard with 1st gear on the slope. When he said what was going on, he gave the error in a few hours. then I went to the service and connected the computer to the tool. A part called egr (or edr) failed. We tried to delete the fault and try again. then we changed this piece. the master said that he could still give the same fault and the brain should be repaired. then he fixed the brain and made no mistake again. There is no problem with traction at the moment. I hope that it will not come out ... the others are on you;)
Why would you reproduce the error if you changed the track? I couldn't understand the reason for the brain repair.
Was the master familiar? How much did you pay?
08.05.2020 18:08 # 8
barishrocker
said there was a risk of repeating this error. master familiar. I paid around 1500TL for glass opening buttons, egr exchange and brain repair. Actually, the same day my brother went to reinforce the company car on our own. it also connected the cables upside down. it may also have malfunctions. even the master said he might have triggered that fault ...
08.05.2020 18:08 # 9
oktobus2
my friend had a normal lpg attached to my vehicle in my previous vehicle and I had that problem. Now, I bought my new ATIKER OBD system with 307 XT. no problem as far as i heard it didnt give this error in obd system, i dont feel the transitions. VERY SUITABLE FOR FUEL I made 435 KM ROAD WITH 95 TL (LPG) (SEMI-HALF BETWEEN CITY)
08.05.2020 18:08 # 10
cansytnn
my car can never be related to 1.6 hdi lpg
2. side I already paid a total of 6400 TL to the engine rectifier. I do not have to pay 1500 more, nor do I have the power to withstand the traction, there is no difference in traction again.
08.05.2020 18:08 # 11
fexzi
6400 TL? what if you paid money and bought 407 or something
08.05.2020 18:08 # 12
cansytnn
We even gave 6400 very difficult, we made it guaranteed in a private service in Ankara, so we had no situation to trade.
08.05.2020 18:08 # 13
elsoberano
[QUOTE = cansytnn] We gave even 6400 very difficult, we made it guaranteed in a private service in Ankara so we had no situation to trade [/ QUOTE]
ank if not special. Which service did you have? Gasoline catalyst oxygen sensors can cause this malfunction. I also have the same problem. The masters connect to the LPG immediately.
elsoberano 2013-12-19 21:39:03
08.05.2020 18:08 # 14
barishrocker
If you don't connect anything to the computer, do not force it, I think. My vehicle obviously fell out of traction. Even in 1st gear he was getting sick. Thank goodness now ...
08.05.2020 18:08 # 15
cansytnn
[QUOTE = elsoberano] [QUOTE = cansytnn] We gave even 6400 very hard, we made it guaranteed in a private service in Ankara so we had no situation to trade [/ QUOTE]
I did not have it done in the authorized service.
08.05.2020 18:08 # 16
cansytnn
[QUOTE = barishrocker] If you don't connect anything to the computer, do not force it, I think. My vehicle obviously fell out of traction. Even in 1st gear he was getting sick. Thank goodness now ... [/ QUOTE]
There is a fact as well, but if I give so much money and still get on an irregularly damaged vehicle, what should I do then peugeot u ?? What would you do if you empathized and put yourself in my shoes?
08.05.2020 18:08 # 17
reality59
[QUOTE = bitter] This problem has recurred in me 3 times 1.6 hdi vehicles usually gives this error when the air activator is dirty and the fuel filter is full. Clean the air flow meter with the filter and replace it if the filter has not changed recently. [/ QUOTE]
My teacher probably encountered the same problem in this direction as well, we washed the flow meter with gasoline and cleaned it with compressed air on other parts.
Are there any air pollution factors such as egr, floor cancellation in your vehicle?
There is an event called co2 release, the brain may perceive it too much in vehicles and as a result it may give such an error .. etc. etc.
I cleaned it with pressure gasoline in my vehicle and it improved. I have not received such an error for about 7-8 months.
08.05.2020 18:08 # 18
azade53
I had the same problem. definitely fuel residue, clean the fuel tank,
and, whenever possible, try to get fuel without dropping the fuel tank needle too low. your problem will be solved.
