THE AMPI SELECTION IS OPEN TO COMMENT ..
08.05.2020 17:55 # 1
berkejack1
I have found amplifiers as follows, which one do you prefer? My main ones
600WATT 100 RMS OVAL HOPORLOR SET PIONEER 4OHM 5 WAY
Pioneer TS-G172CI 17 cm, Mid (Component) 280watt 50rms 4OHM
IN ONE, I CAN THINK 2 BASS IN THE FORWARD GRAIN 1000w 250rms 4 ohms
WHAT SHOULD I BECOME BETTER TO PREFER THE AMPHIA FORWARD?
HERE: GIVING MYTH WITH MY AMP PIONEER TS-G172CI FROM THE AMFI TO YOU
http://urun.gittigidiyor.com/garaj/roadstar-rda6040-anfi-ve-rdh620c-mid-takim-set-92754139
AMPS
http://urun.gittigidiyor.com/garaj/eversonic-es-4980-4ab-oto-araba-anfisi-2000w-91880667
http://urun.gittigidiyor.com/garaj/mg-audio-mg-600-4-amfi-4kanal-2400watt-oto-anfi-92672250
http://urun.gittigidiyor.com/garaj/edison-ed-604l-4-kanal-2400-watt-oto-amfi-87545566
http://urun.gittigidiyor.com/garaj/hifi-hf-404-mosfet-cikisli-2400-watt-oto-amfi-92667395
http://urun.gittigidiyor.com/garaj/roadstar-rda6040-amfi-4kanal-2400watt-oto-anfi-92706388
http://urun.gittigidiyor.com/garaj/jbl-gto-75-4-yerine-ass-75-4-anfi-oto-amplifier-93219156
http://urun.gittigidiyor.com/garaj/oto-anfi-pioneer-4-cikisli-as5050-1000-waat-92494117
http://urun.gittigidiyor.com/garaj/ma-audio-m4-50-4-kanal-1800-watt-stereo-amfi-90337219
http://urun.gittigidiyor.com/garaj/jameson-usa-604-4kanal-1500w-amfi-sifir-garanti-92725292
08.05.2020 17:55 # 2
tigerland
Get bass xetec 6 channels if bass enters
08.05.2020 17:55 # 3
berkejack1
bass will enter after a long time.
08.05.2020 17:55 # 4
tigerland
If you are going to get 2 amps then I know that you will need to get mono bass after 4 channels first. I suggested in one amp to finish the job.
08.05.2020 17:55 # 5
berkejack1
it will be the only amplifier, 2 myths compenant and 2 ovals will be connected to the first 4 channels in 6 channels, so you will not lose performance.
08.05.2020 17:55 # 6
Alicilik
Sir, there are channels to prevent loss of performance. If you connect two speakers to one channel, the performance will drop, but when you connect separate speakers to each channel, there is no problem.
You say I will use double bass. A normal bass already requires a mono amp, but usually the strereo amp is bridged to gain. You say I will use double bass.
My personal opinion is to use a double amp. I use a 5 channel amplifier myself, much higher than the products you dispose of, but this time it gets very hot when full power works.
You can use the two amps as follows;
1- Two strereo 4 channel amps are taken, two channels of both amplifiers are bridged and one bass is applied.
2- A stereo 4 channel mono amp is received, stereo speakers receive mono bass.
The products in the links are 3 up to 5 down similar products. You can choose according to your price band. Of course, 2400w ones are the priority though.
If you are thinking about the bass too long, get a stereo for now and decide on the second amplifier while buying the bass.
08.05.2020 17:55 # 7
Alicilik
[QUOTE = berkejack1] will be the only amplifier, 2 channels compenant and 2 ovals will be connected to the first 4 channels in your 6 channels, so you don't lose performance.
With both blood, a mid team or oval speaker goes, teacher. There will not be 2 mid-compenant for 4 channels. Are you thinking of bridging channels?
08.05.2020 17:55 # 8
[QUOTE = tigerland] If bass enters, get 6 channels of xetec [/ QUOTE]
this amp is very good and when I go to it, I will get my tape cable or something.
08.05.2020 17:55 # 9
Alicilik
[QUOTE = Alper`EN AKSU] If [QUOTE = tigerland] bass enters, get xetec 6 channels. [/ QUOTE]
Alper I need a solid deck converter, if you don't bother, can you ask at a suitable time?
08.05.2020 17:55 # 10
I ask, no problem, I will return to you in two hours
08.05.2020 17:55 # 11
fexzi
I have a Jameson 505 amplifier, and I have a guaranteed 10 days of use.
08.05.2020 17:55 # 12
berkejack1
[QUOTE = Receiving] [QUOTE = berkejack1] will be the only amplifier, 6 channels will be connected to the first 4 channels, 2 myths compenant and 2 ovals will not be lost from them.
As you said, let me do it, then, teacher, I do not know what channel bridging is.
http://urun.gittigidiyor.com/garaj/pioneer-ts-g172ci-17-cm-mid-komponent-bass-taki-91097819
http://urun.gittigidiyor.com/garaj/pioneer-ts-a6995s-600-watt-hoparlor-yeni-model-90999530
I would like to have something that I can connect directly and get full performance.
And this amp will not run out of battery, right?
08.05.2020 17:55 # 13
tigerland
I used JBL 755.6, 1 bass, 2 sets of mid, 1 bass. If you say you can put one of the mid teams on tape and finish it in one amphitheater. I didn't want to deal with a capacitor or something. of course there are more knowledgeable friends who have helped you :)
By the way, I know that xetec also has the same circuits as the tradesman jbl. He came to my mind first because of the quality
08.05.2020 17:55 # 14
Alicilik
The event we call channel bridging is the merger of the two legs. In this way, you transfer the power of the two channels to a single organ. The output is mono but the power is increasing.
For example, if an amp is 4-channel and 60w rms can be driven to each channel at 4ohms, you will use two channels to normal speakers, if you combine the other two channels (bridging), the nominal power you get here will be more than 60 * 2 = 120.
So a medium stereo amplifier will be enough for you. If you say I will improve the system (which you are talking about double bass) my advice will always be two amps.
I have an amplifier that gives 4 * 90w rms + 1 * 300 rms at 4ohm. If my mind is 100-200 whatever it is today, I would definitely take the mono amp apart. Or I would use two solid stereo amps.
Eret said xetec 350.6 is a really powerful amp. If I am not mistaken to get this patented German production series, these vectors have the new series xircuit series 172.5.
Looking forward to me, it would be better to have two stereo amps because you can fit the stereo amp in every way, the mono amp does nothing but bass. Double amps take up space and their cost is more expensive than a single amp. These should also be taken into consideration.
There is no such thing as battery drain. ZAten amp will work as long as the tape is working. Make good connections. If the battery is not dead, there is no fear. See if I try too hard while the engine is not running.
Also, use a capacitor after installing a bass for efficiency. An average of 500w rms e 1 farad is required 2 farad be comfortable for a capacitor plug.
08.05.2020 17:55 # 15
berkejack1
As you said, do you know a stereo amplifier that gives 4 * 70-100rms in 4ohm?
And which of the amps I linked to will see my job the most
08.05.2020 17:55 # 16
Alicilik
Most of the amps above have the same feature. The first eversonic says 4 * 80 one, the others 50 or 60
It will work, all of them have 207 cousins, and the guy has connected the oval speaker to the channel. Both increased resistance and ruined the sound. When the strength increased, the speakers were not able to get the required power. So it works with an amp like these, it sounds like a normal connection, so it will sound good.
08.05.2020 17:55 # 17
berkejack1
So how do you think eversonic wrote a 80x4 rms line?
08.05.2020 17:55 # 18
Alicilik
[QUOTE = berkejack1] So how do you think eversonic wrote a 80x4 rms line? [/ QUOTE]
Sir, all the brands on that list are the same, only the products that have different names. Of course, it can not give 80w rms at full power.
08.05.2020 17:55 # 19
berkejack1
Well, if I buy something higher, would it be harm or a warming problem?
08.05.2020 17:55 # 20
berkejack1
LOOKING A LITTLE AND DOWNLOADED OPTIONS garage / roadstar-rda6040-amp-and-rdh620c-mid-tool-set-9275413960RMS-2400W MG AUDIO MG-600http: //urun.gittigidiyor.com/garaj/mg-audio-mg-600-4-amfi-4kanal -2400watt-auto-amplifier-92672250104RMS-1800W ASS 75.4http: //urun.gittigidiyor.com/garaj/jbl-gto-75-4- instead of-ass-75-4-anfi-oto-amplifier-93219156KOMPENANT AS A TEAM 2 MY OPTION IS Pioneer TS-G172CI 17 cm, Mid (Component) Maximum Input Power 280W Rated Input Power 50W Impedance 4Ω ROADSTAR RDH620C Maximum Input Power 360W Nominal Input Power 120W Impedance 4Ω
Page : / 2
