the airbag lamp is on
08.05.2020 21:01 # 1
sckn22
Hello friends, I have a 2006 model 307 vehicle. The airbag lamp flashes intermittently for 2 months. Then it goes out by itself. I went to the industry the other day, they connected it to the computer. He gave the right front airbag error. He disassembled the sockets under the seat and gave another error. After connecting the sockets, that error disappeared. Why does this happen to anyone?
08.05.2020 21:01 # 2
talip206
There may be several reasons, but it is generally related to sockets.
1. Remove the plastic under the steering wheel. (Plastic under the signal arm or something). There is an airbag socket, it is usually loose. The color of the socket is brown in 206 but I don't know 307. There are already two or three sockets.
2. If your vehicle has more than two airbags, there are airbag sockets under the seats, they may be loose, oxidized.
3. The fuse related to the airbag in the fuse box inside the vehicle can make contact. Replace the fuse and check the bottom of the track for looseness, oxidation.
4. There may be a break in the airbag coil on the Com2000 handle. The place I am talking about is the part with headlight signal and wiper arm. Generally, as you turn the steering, the connection is broken and gives a warning. Zero is expensive, repair is more convenient. But don't try to change and repair before trying other possibilities.
talip206 2018-09-15 22:23:04
08.05.2020 21:01 # 3
sckn22
When connected to the computer, the error appears on the airbag in the right passenger seat. The socket under the armpit slipped and gave a different error. When the socket was inserted, it got better, so it's not like the armpit. Shouldn't the driver airbag fail, even from the winding? Since the front is in the right passenger airbag, where is the second place I should look if the error is not from the sockets under the seat?
Actually, my intention was to have it done in the service, I called 10 years old, we do not connect it to the computer, he said. When I said we will change the installation, or the brain will change, we will find it by trying to find 8-10 thousand liras. If you find it by experiment, what is the difference from me? Already if there is such a big problem, it is constantly lit for 2 months.
08.05.2020 21:01 # 4
talip206
As the center of the airbag is in com2000, the passenger can also give the airbag error from there. Which side of the cable is broken, I think that side will fail. But your problem is likely to be related to contactlessness. You check the sockets and fuses. Do not hurry, you will find the experiment.
I don't understand these services either. No, we do not buy the vehicle with lpg. We do not buy the vehicle over the age of 10. If they are not ashamed, they will not let the guaranteed vehicle in.
talip206 2018-09-15 23:15:04
08.05.2020 21:01 # 5
sckn22
[QUOTE = talip206] As the center of the airbags is at com2000, the passenger can also give the airbag error from there. Which side of the cable is broken, I think that side will fail. But your problem is likely to be related to contactlessness. You check the sockets and fuses. Do not hurry, you will find the experiment.
I know that when the Com2000 is in, the horn is not working. He must have made a mistake when he turned the steering wheel. I tried a lot. I could not turn on the malfunction lamp. Where are these insurances likely to be non-contact?
08.05.2020 21:01 # 6
Orcun.Dmr
If both the airbag lamp and the passenger airbag lamp are on, remove the red 10-fuse located in Bsi with the ignition off and insert it again, and it will probably be solved.
08.05.2020 21:01 # 7
sckn22
Today, while the fault lamp was on, I took it to the industry and got it connected to a computer and it gave such a mistake.
08.05.2020 21:01 # 8
sckn22
Who knows where this side impact sensor is? The electrician says I do not understand, the service says that I do not look over the age of 10, the parts are not produced anyway. No, what should we do?
08.05.2020 21:01 # 9
There are problems with the underarm sockets, sir. You have to find a good electric master who understands peugeot. as I understand it, the side seat gave an error with the airbag. there is a break in the cables, he said open circuit. or oxidation in sockets
08.05.2020 21:01 # 10
I even found a video about the same error now.
[TUBE] 38e9zqltbı the [/ TUBE]
08.05.2020 21:01 # 11
sckn22
[QUOTE = sonerkyl] There's probably a problem with the underarm sockets, sir. You have to find a good electric master who understands peugeot. as I understand it, the side seat gave an error with the airbag. there is a break in the cables, he said open circuit. or oxidation in sockets [/ QUOTE]
The electrician side impact sensor here said it was broken, the other said the error he gave might not be correct because the software was not original, I was surprised what I would do. I do not have much English, I think it is about the lack of sockets and cables in the video. I'll do it myself if I know where to look. If there is no contact in the connectors or cables, will it give an error as a side impact sensor?
08.05.2020 21:01 # 12
No brother impact sensor so I don't think it will break down easily. If there is a disconnection in the cables as in the video, the sensor will not see because the circuit is not completed, which causes the sensor to be perceived as defective. My brother doesn't need to know English, just check the wires under the right passenger seat, just like in the video, the places that are already broken are obvious. Because the harness is next to the sled, when it moves the seat back and forth, it cuts the cable over time or because it touches the iron of the seat, it chases and lights the malfunction code.
08.05.2020 21:01 # 13
sckn22
So let me take it to an electrician, check all the wires and sockets under the right seat. When nobody wants to approach, detect the fault. At least I'll eliminate simple possibilities. I do not want to tamper with the master who knows the job because they do not give confidence. There is sorento, which has just come to the beginning of my new system. Changed result esp light is burning again :) The motor that got back to 4x4 transition was broken, they fixed it and they fixed it. 500tl garbage .. they said it had to change, but if you eat :) so I don't trust the machines in the industry.
08.05.2020 21:01 # 14
Just as my brother does not find a reliable master, many of them are looking for change with new ones. they are far from dealing with simple problems. If it is constantly blinking, there is a disconnection in one of the exact cables, brother.
08.05.2020 21:01 # 15
Celal2626
may be under the plastic of the right seat belt
