The air conditioning fan stops soon
08.05.2020 14:52 # 1
mutlu
It is working when I first opened the digital air conditioner of my 2004 model 307 Sw car. But before a minute passes the fan stops blowing. After it is cooked from the heat inside, it comes back into operation for about 1 more minute and stops again. I've been running like this for a year. It is enough. In addition, the right side started to blow hot for 1 month.
08.05.2020 14:52 # 2
BuRCaK
automatic method does this, or when you use the air conditioner manually?
08.05.2020 14:52 # 3
I had a similar problem. Suddenly he was silent, and when he entered the pit or something, he worked spontaneously. There was oxidation in the sockets of the cables going to the fan motor of the air conditioner. For this reason, he was contactless. the master canceled the socket and connected it directly to the solder and put the fan back in place. It is currently smooth. Total cost is 15 pounds. Labor costs.
Of course, your problem may be different.
08.05.2020 14:52 # 4
mutlu
I couldn't find how manual work is. I think it is manual only when typing A / C on the screen. Because there is only Auto button in the air conditioner. It always keeps the same fault. I left it to the service, they will look today.
08.05.2020 14:52 # 5
tugrabozan
have your fans checked. When the air-conditioning radiator overheats, the thermal switches on, disabling the compressor.
08.05.2020 14:52 # 6
murdak
Hello there,
Gokhan (nickname is happy) Mr. dun I sent you a special message because I have the same problem. You have said that you will leave the car in service. I would be glad if you can inform me about the result.
532 650 10 67
08.05.2020 14:52 # 7
mutlu
They called from the service yesterday. The problem was in the heating engine, but I could not ask in detail. When I receive the car, I learn it and write the result. happy 2010-08-27 11:25:54
