the air conditioner turns itself on
08.05.2020 18:26 # 1
baksi
2004 307 xt. It doesn't always happen when I turn the ignition key one turn after my car has stopped for a long time, but the air conditioner turns itself on. I took it to the service, connected it to a device, got a printout, "intermittent malfunction: air conditioner residence-I know what is delayed or rotor, something like that -block". The service masters have reset it, they said, come and see. They said one day I left nothing. But this morning the air conditioner turned on again automatically. why is this happening? what is the solution?
08.05.2020 18:26 # 2
hsnsnl
There is an auto sensor in the digital air conditioner.
08.05.2020 18:26 # 3
ahmet_bjk
I did not know why, but I was curious about something, did the service charge a fee even though it could not be done?
08.05.2020 18:26 # 4
herry
[QUOTE = hsnsnl] There is an auto sensor in digital air conditioner, my teacher may be from him, it is broken, big chances [/ QUOTE]
Thumbs Up
08.05.2020 18:26 # 5
baksi
No, I did not give money, even if there is no solution other than 10 TL fault detection for air conditioner. LOL Although the air conditioner has detected the problem or the device they connect is intermittent malfunction or something, they say that there is nothing. I will go crazy.
08.05.2020 18:26 # 6
106fb
I have the same incident as well. I don't think this is a problem, I know that several 307s have the same.
08.05.2020 18:26 # 7
baksi
The diagnosis is exactly: intermittent malfunction: the rotor of the in-car temperature probe is blocked
Yahu service paid 1500 TL for this. If not, they said + the brain will change. In the industry, the air conditioner laughed, what is a sensor from a piece of 40-50 TL? I mention. "I don't have it next week," he said.
08.05.2020 18:26 # 8
206cc57
My car is 206 cc, digital air conditioner, it turns on when I turn the ignition and it starts when I run it, it is less on hot days I think it happened on this day. I didn't think it was a malfunction.
08.05.2020 18:26 # 9
memet
Hello friends, I also got the 2004 1.6 quilosilver war tool to cancel the ass air conditioner that I bought. I would be glad if you help me with your face against anything before.
08.05.2020 18:26 # 10
jackal67
I have 307 chronic problems and I have the same problem :) I would appreciate if my friend resolves the fault and inform us here.
08.05.2020 18:26 # 11
memet
He said he might have stuck 1500 TL between my friend, but I didn't show it to the expert, of course.
08.05.2020 18:26 # 12
mertdemiray
Hodja, did you solve the malfunction, would you reply?
I have that same problem. My car 2003 307 SW Pack 1.6 gasoline automatic gearbox with automatic air conditioning.
Our problem is similar: I park my car in the evening (I am sure that the air conditioner and similar electronic accessories are turned off when the ignition is switched off, radio tapes, etc.). I come in the morning, open the ignition, check before starting, There is A / C on the air conditioner control panel. When the vehicle starts and starts, it is directly activated in automatic air conditioning. According to you, the brain of the vehicle has recorded an error. The error you said: " intermittent malfunction: the rotor of the in-car temperature probe is blocked." This malfunction speaks of the sensor and the fan motor around the front panel, which measures the interior temperature of the vehicle and transmits the ambient temperature to the air conditioner. (There is a fan motor and ntc heat detection sensor in the middle) The reason for being a fan is to draw the air inside and to pass the sensor over the correct temperature value. According to the error you said, the motor (rotor) of this fan is stuck and means it doesn't work. So far okay, but is it normal for A / C to be active at the time of contact because of this error?
Were you able to fix the problem by cleaning or replacing this part?
08.05.2020 18:26 # 13
xmen
Pressing the digital air conditioner windscreen button automatically activates the air conditioner. is this normal? Are all the digital air conditioners of the 307s like this?
08.05.2020 18:26 # 14
Faruk
[QUOTE = xmen] digital air conditioner activates automatically when you press the windscreen button. is this normal? Is all the digital air conditioning of the 307s like this? [/ QUOTE]
yes, so do I. I want it not to be so, but when I press it for auto or glass, I turn off the air conditioner immediately.
08.05.2020 18:26 # 15
xmen
[QUOTE = Faruk] [QUOTE = xmen] digital air conditioner automatically presses the windshield button and the air conditioner is activated automatically. is this normal? Is all the digital air conditioning of the 307s like this? [/ QUOTE]
[/ QUOTE] Interesting why they needed something like this ...
08.05.2020 18:26 # 16
riderzist
[QUOTE = xmen] [QUOTE = Faruk] [QUOTE = xmen] digital air conditioner activates automatically when you press the windshield button. is this normal? Is all the digital air conditioning of the 307s like this? [/ QUOTE]
[/ QUOTE] Interesting why they needed something like this ... [/ QUOTE]
because it takes the windshield vapor out of the air conditioner.
look now, in the eco mode, the windshield vapor goes very late, but since the air conditioner has the feature of dehumidification, it ensures that the glass gets the steam as soon as possible.
the reason is very logical! So it's normal.
no problem, you try to adjust it manually
08.05.2020 18:26 # 17
riderzist
[QUOTE = look] 2004 307 xt. It doesn't always happen when I turn the ignition key one turn after my car has stopped for a long time, but the air conditioner turns itself on. I took it to the service, connected it to a device, got a printout, "intermittent malfunction: air conditioner residence-I know what is delayed or rotor, something like that -block". The service masters have reset it, they said, come and see. They said one day I left nothing. But this morning the air conditioner turned on again automatically. why is this happening? what is the solution? [/ QUOTE]
The air conditioner is digital and it has sensors in the evening. because it adjusts itself and automatically according to the temperature you set.
It usually does this in very cold winter, but if you leave the heat too high, it will do it in normal cold. in summer, when it is against the sun in very hot weather. this happens every 307. because it is written in the booklet! :)
