The air conditioner suddenly stopped cooling |
| 08.05.2020 17:49 | # 1 |
| 08.05.2020 17:49 | # 2 |
any idea?
| 08.05.2020 17:49 | # 3 |
fexzi |
Is digital air conditioning?
| 08.05.2020 17:49 | # 4 |
no analog
| 08.05.2020 17:49 | # 5 |
fexzi |
Incompatible gas may have been printed. The trip that should be pressed on every vehicle is not universal, it may be from it.
| 08.05.2020 17:49 | # 6 |
If the air conditioner gas leak is too small, a colored gas is pressed to detect, 3-5 days later, it is detected with purple light and glasses.
| 08.05.2020 17:49 | # 7 |
I think it was gas R134a & nbsp;
| 08.05.2020 17:49 | # 8 |
[QUOTE = _ali_] If the air conditioner gas leak is too small, a colored gas is pressed to detect. 3-5 days later, it is detected with purple light and glasses. [/ QUOTE] |
| 08.05.2020 17:49 | # 9 |
AydinBeyol |
my vehicle was filled with gas. it was later found to be a leak. I don't know what kind of system yours is filled with, but I think they should go to the same place again and find out if there is a leak.
| 08.05.2020 17:49 | # 10 |
the same problem was with me my brother had the air conditioner dryer filter clogged my car now started to blow like ice, the air conditioner is working everything is normal, your voice sounds like you say it clicks but it was not cooling but it did not cool the same problem in my problem I think my car is clogged if 113 km is the same km ... < a href = "http: //www.astro nklima.com/1540205-peugeot-206-i" target = "_ blank" rel = "nofollow"> http://www.astronklima.com/1540205-peugeot -206-i & nbsp; filter, as this picture, they discharge and disassemble the gas right next to the fan, you can blow it with your mouth and try it if it is not airy ...
| 08.05.2020 17:49 | # 11 |
[QUOTE = AydınBeyol] gas was filled to my vehicle. it was later found to be a leak. I don't know what kind of system yours is being filled with, but I think they should go to the same place again and let them determine whether there is a leak again. the machine said that it wouldn't press the gas
| 08.05.2020 17:49 | # 12 |
[QUOTE = yavuz_0051] I had the same problem, my brother had an air-conditioner dryer filter clogged, I changed my car now started to blow like ice, the air conditioner is working normally, the sound you say is coming, it sounds like clicking, but it does not cool. . http: //www.astronklima. com / 1540205-peugeot-206-i & nbsp; filter, as this picture, they discharge and disassemble the gas right next to the fan, you can blow it with your mouth and try it if it is not airy ... / div> It was cooling smoothly for 1 month, which I did not understand alone. I don't know, I will try to show it somewhere as soon as possible.
| 08.05.2020 17:49 | # 13 |
We were going to fill in the new car we bought, the man installed the machine, but there is a leak in this, let's not fill it in 2-3 days.
| 08.05.2020 17:49 | # 14 |
[QUOTE = Ssedo] I was going to fill in the new car we were going to buy, the man put the machine on, but he said that it will be completed in 2-3 days. I filled it up to 90 liras, I used it for 1 month, what should I say :)
| 08.05.2020 17:49 | # 15 |
Hodja, I want to check this part of the car. . What a piece. . Reviews div>
