The air conditioner sometimes cools and sometimes it does not.
08.05.2020 21:16 # 1
bozgoc
Hello dear friends,
I have 207 1.6HDI, my car is 2012 model and equipped with Allure. I am very satisfied with my vehicle.
I had periodic maintenance at 117 thousand Km the other day, we changed the engine oil, oil-diesel-air and pollen filters. I noticed a few days later, there is a problem with the air conditioner, I turn on the air conditioner, AC is on the screen, but the famous compressor does not sound from the engine, the degrees are generally at 18 degrees on both sides. He took it to the mechanic, he said, let's connect it to a machine and let's press the gas, and I said OK, and he said that the 7-year-old vehicle might have lost its gas effect.
Gas filling process is finished, checks have been made and the air conditioner is working super cool as well.
But the next day, I noticed the problem again, this time when I turn on the air conditioner, the AC light turns on and the compressor starts to sound. If I have a friend who has settled with such a problem, I will request their support and information for the solution of the problem.
I wish you all good and accident-free uses.
08.05.2020 21:16 # 2
yusuf333
I have that same problem. There is a sound called snap at the bottom. The load is on the engine, the air conditioner comes on and cools down. Then it sounds like clicking again, as if it is deactivated, the air conditioner does not cool.
My vehicle is 2001 model 206.
Is there anyone with this information or insurance?
08.05.2020 21:16 # 3
Ouzhan0734
We had a similar error in Ford Connect. The air conditioner master replaced a part of the compressor and the problem was solved. Before that, the air conditioner was cooling when he wanted it. Thanks to the replacement part, the compressor started to operate regularly. It cost like 350 TL.
08.05.2020 21:16 # 4
EGE_207
The air conditioner works on my vehicle, it is cooling when the ac lamp is on, but there is no ice cooling so there is a solution about it?
