the advice to clean the engine ??
Homepage » PEUGEOT MODIFIED PLATFORM » 307
08.05.2020 17:27 # 1
Alicilik
Last week, I cleaned the engine of the 3 cars in detail, there was no problem.
There is a product named Atas brand protes. Depending on the dirt of a robust oil introducer chemical engine, you dilute it 1/8 to 1/10 and apply it everywhere under the hood by spray. A plucking substance takes off all dirt. After waiting for a while, I have a pressurized washing machine and a broken making apparatus. I broke it up with it, I kept the engine for 5 minutes and adjusted its pressure according to its place, made it with water and dried with a cloth (you can close it with msensor and brains.) Then I applied it to the plastics with a turtle wax protector spray. /> Applications,
2011 206+ my own vehicle
2004 corsa father's vehicle
1994 3.16 lpg I applied it to my uncle's vehicle
08.05.2020 17:27 # 2
Burak
My engine got very dirty or I got into the mud the other day, the motor protection cover is not in the bottom, it was left in the mud. How we clean it.
08.05.2020 17:27 # 3
Alicilik
[QUOTE = onurazgin] I don't think of calling the engine water. I am not expecting anything from the bidet bsi or something, I do not expect anything professional, they washed it with a diesel once in the service, but I repented it with a diesel ... [/ QUOTE]
The engine with a diesel is washing the engine
But you should use an active substance without water. Engine cleaners consist of dense degreasing acids. This accumulation or prolonged contact with any substance can lead to irreversible problems. The spray, engine, pad, rim cleaning that I use will see your job very well in order to put oil and dirt on the metal, but it will also have a plastic and rubber deflection effect on the engine or its surroundings, so I firstly ripped it off with pressurized water. I decreased the pressure when it came to the sensors and the fuse box.
The result was excellent. After a little surface was installed, I started the vehicle for 5 minutes.
08.05.2020 17:27 # 4
Alicilik
Hodja say wd40 oh my. We are the only nation that uses the WD40 to clean the engine. Wd40 rust binder is an oily substance. Ha diesel ha wd40. Never dilute a little washing water with water, put it in the spray booth and apply it to the plastics, but it can get white deposits. where the cables that come to the motor are connected, you can usually cover the sensor with their cloth. The machines are 160bar and leave the sensor and the motor inserts the engine :-D
The tool I use is 130 bars.It is pressure enough to hold the pressure on the hose.
If you say I try to do it, you can rent it if you think it is the construction markets. also
08.05.2020 17:27 # 5
Alicilik
[QUOTE = onurazgin] unfortunately I'm a victim of straight logic. but as I said, he repented. those oils kept dust, wiping it by hand and the engine like cillop has turned into a long issue that is hard to clean right now ... anyway, the only thing to do after this point is to wipe it by hand, but I am hesitant about the substance we are talking about as `` effective '' .. [/ QUOTE]
Wd40
Diesel
Petrol
Alcohol
Gogus polishing sprays sutler
Plastic parts protective polishers
paste polish
Don't say goodbye. Never dampen the sponge and clean it with a dishwashing detergent.
Watching the active substance with water is important if it stays intensely on the plastic and rubber parts.
I came to my face. I buy these products from the wholesaler. While buying from there, we put this item in a half liter pad. I went home the next day, my mother called, and this liquid melt the bottom of the pet, flowed into all the pantry and started to melt the broken detergents next to it. What does EBi think don't do to this engine assembly? I also diluted with water, and then applied with water, and I washed with water and water without waiting too much. Follow the product descriptions of autoglym and chemicalguys, the guys clean the dodge la dr 2012 as I do, with more powerful tools.
In the meantime, I heard a lot of water and washing problems but I was very confused about the application. If you pay attention, it is not a problem and it is worth what you do. If the washers under the apartment or the children at gas station wash, let the car run
08.05.2020 17:27 # 6
Alicilik
[QUOTE = onurazgin] Even if I wash it with water, the pressure event will be only as much as the city mains pressure ...: D: D anyway, we will see the engine is not very dirty, but wd 40 thanks ... :) I wash it why not ... (when it comes to gas and burns bsi): D [/ QUOTE]
BSI does not go to it in the vehicle, it is easy to use ECU and main fuse box important
08.05.2020 17:27 # 7
Alicilik
[QUOTE = Honor] I have the fuse inside the vehicle under the bonnet of the ... look 1.6 hdi [/ QUOTE]
Bsi which mind is there to carry pejo
08.05.2020 17:27 # 8
Alicilik
[QUOTE = onurazgin] is actually more useful, the mooring plug is already useful for the fuse box inside ... but it is not dangerous at work ... [/ QUOTE]
My personal opinion is that the current coming from the battery is evaluated under the first hood and the vehicle is be transferred into. it will prevent possible electrical accidents.
Bsi is a brain in itself. works with a processor in itself. Temperature is affected more by factors such as humidity, but what we call a fuse box is a simpler mechanism. It is good that the fuse box is also under the hood with a high burning hazard due to instantaneous current movements.
Bsi;
< br> I couldn't find a clear photo, but the fuse box in the far right center seems to be more prone to use this way
08.05.2020 17:27 # 9
Alicilik
[QUOTE = honored]
Wasn't the fuse box here? : Q I see fuses there, am I wrong? [/ QUOTE]
Both have fuses, but as I said, the BSi is usually under the steering wheel. BSi in this photo. There is also an OBD socket on the BSi.
The rightmost middle box in the other photo is the fuse box. It is not as featured as BSi. It distributes the current in general. Reviews
08.05.2020 17:27 # 10
tigerland
turtle Wax engine cleaning spray + overlay :)
08.05.2020 17:27 # 11
rockwaryumm
I don't remember the brand & nbsp; I go deeply with a motor cleaning spray and sponge, of course, always a lining spray for tough stains, but dry thoroughly the combustible after all "LOL" I go with milk in plastic hitch and personally after cleaning it becomes more sweet "LOL" & nbsp; I think engine cleanliness is a priority, I like it even more from the outside. The hood is clean. "LOL"
08.05.2020 17:27 # 12
emre_akdag
Thank you [QUOTE = honored]. They talked about the balata spray or something, the best I have never been smeared with. there is no harm. I personally do so. Do not touch the water, as other friends say. no need for risk adventure :) there is a tube lining spray, a tube has engine cleaning fluid, the same glass wipe is in the box, there is a sprinkler. a clean defect cloth in one. that is all ;)
08.05.2020 17:27 # 13
Aziz
Let me tell you about my method.
For the sake of practicality, I buy 4 pairs (2 lira) of knitted snow gloves.
Put 1 pair on my hand :) I mix the water with a little mr muscle oil and dirt solution (3.99tl) in the water (a burning odor emerges, do not do it in a closed place) I dive wet and foamy with gloves, wherever I can reach the engine, etc. I can reach the corners with ease and with the fingertips. div>
& nbsp; when we get close to drying or when the dirt starts to dissolve, I wash it with a hose (15 m 8 lira) & nbsp; and its head (3 lira), which turns the normal water into pressure, and then I dry it with enough dry gloves. (2 pieces are enough and I have done this application twice. I was satisfied with 2 different vehicles) if the washers are 160bar, this will be 80 bars or more, but it is useful but not sufficient to wash the bonnet :)
08.05.2020 17:27 # 14
serkan719
When I bought it for the first time, I washed & nbsp;
gold and engine with fresh water.
