The Actioner issue at 308 Auoto6r
08.05.2020 20:12 # 1
hrn 63
hello friends 308 Auoto6r has had an Action problem, so there is a slight noise and vibration while shifting the gears ... I have encountered such a thing before, and what you did for the solution, how much it costs ... what should i do ... thanks in advance ConfusedConfusedConfused
08.05.2020 20:12 # 2
teacher, I don't think the actress will break down easily. As you know the activator, a really expensive piece of zero is about 3500-4000 TL, the pressure and the bearing set is around 1000-1500 TL.
08.05.2020 20:12 # 3
hrn 63
What is this bearing when I change it?
08.05.2020 20:12 # 4
I sent it specially, my teacher has already changed the parts, the training and software updates should definitely be done, or you will be faced with some small knock problems.
08.05.2020 20:12 # 5
hrn 63
Thank you very much my teacher, msjdanda ... Thumbs UpClap
08.05.2020 20:12 # 6
You are welcome, teacher, I hope your problem will improve after the print set change. good forums
