The 407 rear window stop lamp does not light.
08.05.2020 20:00 # 1
407 ERHAN
Friends, as I mentioned in the topic, the rear window stop lamp does not light up, it is warning from the road computer, I have not taken it to the auto electrician yet, if the fault is not caused by the wires or something, only the bulbs inside can be replaced or the complete stop lamp itself is replaced, thanks.
08.05.2020 20:00 # 2
erhan hocam bulbs are changing, they have nails on the sides, you can see when they save. but first of all I would like to see your fuse.
08.05.2020 20:00 # 3
407 ERHAN
Thank you very much, sonerkyl friend, I searched on the internet, I couldn't find a spare glass as the rear window stop lamp anyway, thanks, good day ...
08.05.2020 20:00 # 4
If you call it the 3rd lamp, take it off, erhan hojam
08.05.2020 20:00 # 5
plummedia
[QUOTE = 407 ERHAN] Friends, as I mentioned in the topic, the rear window stop lamp does not light up, it gives warning from the road computer, I have not taken it to the auto electrician yet, if the fault is caused by the stop lamp, not the wires or something, can only the bulbs of the interior change, or the complete stop lamp itself Is changing, thanks. [/ QUOTE]
Get well, I had the same problem. Carefully remove the cover and take a lamp to a location that sells auto electrical equipment for example, you will find it very easy.
08.05.2020 20:00 # 6
407 ERHAN
Thanks again sonerkyl my friend 😉
08.05.2020 20:00 # 7
[QUOTE = 407 ERHAN] Thanks again, my sonerkyl friend 😉 [/ QUOTE]
thank you what multu us if we could help & nbsp; "Smile"
08.05.2020 20:00 # 8
407 ERHAN
Guys, what is the fuse number of the 3rd stop lamp, do you know?
08.05.2020 20:00 # 9
407 ERHAN
Hello friends again, Peugeot is a very beautiful car, luxury, comfortable, flashy but very sensitive car, one of the fault warning lights is off, one is on, I can not understand what is happening, for example I am tired of the esp / abs warning now, also the rear glass third stop lamp malfunctioned. , only the bulbs have changed but now it is often on the road while driving, it often fails to tackle the rear taillights, this is a very frustrating situation, sometimes it warns as a left taillight, sometimes it is a general warning as taillights, it really stops when it gives a malfunction warning I do not know whether the lamps are blinking, what could be the reason of this situation, what should I do? 407 ERHAN 2017-05-11 19:49:30
08.05.2020 20:00 # 10
Hello erhan abi, the abs / esp warning is usually caused by the malfunction of the sensors on the wheels. The reason is that when foreign substances such as mud on the sensor accumulate, it gives this error because it cannot read correctly on the sensor. The problem with the stop lamp can also be from the sockets. We need to take a look at the stops, oxidation etc. Do you have to clean the sockets with contact spray.
08.05.2020 20:00 # 11
407 ERHAN
Hi soner, how are you brother, I hope you are fine, as always you helped me again, I don't know what to say to you, thanks, man, okay, I understand, brother, I will take the car to an auto electrician like next week, when I go I will tell the master the way you say, I will let you know the result from here, so that the vehicle will not tamper with it, I will be at the end of the holiday in Ankara, I will come to you if there is nothing wrong.
08.05.2020 20:00 # 12
Thank you, brother, thank God, we are running home. If we can help, we are happy that you don't have to go to the auto electrician if you buy one oil-free contact sprek and clean the sockets well, there will be no problem at the stops. The abs / esp sensor is generally problematic in the rear wheels. See you when you come to Ankara, brother, not without drinking our tea. Smile
08.05.2020 20:00 # 13
407 ERHAN
Thank you so much Soner, thank you, you have helped me a lot, I will try to practice what you said, hope to see you, have a good job, stay healthy, stay calm ...
08.05.2020 20:00 # 14
Thank you brother, stay with you. Good Friday.
08.05.2020 20:00 # 15
407 ERHAN
Wink
08.05.2020 20:00 # 16
mistercasper
I wonder now that I am a 407 user, but I did not see the broken bulb fault light on my car recently.
08.05.2020 20:00 # 17
strangely it should normally be warned if it is possible to enter and close the warnings, it may be turned off.
08.05.2020 20:00 # 18
mistercasper
I wonder if how many models of Erhan brother's vehicle was in 2008 and the top models, the tire pressure sensor was canceled.
08.05.2020 20:00 # 19
407 ERHAN
my vehicle is the 2006 model 1.6 hdi comfort model, I hope my 407 warns everything, it warns the fly fly, I'm tired of it, I'm distracted while driving the vehicle, if it gives a warning, it's not a problem. 407 ERHAN 2017-05-18 10:42:44
08.05.2020 20:00 # 20
407 ERHAN
Friends, I forgot to tell you about the warning lamp on my car that is faulty, it doesn't always do when I'm on the road, not only when I press the brake, so it doesn't happen when I press the brake, but also started to make this fault warning after the auto electrician repair the 3rd stop lamp, the mechanic He first said that the reason for the 3rd lamp is not lit, it was replaced by the bulbs, when the lamp did not come on again, this time the cause of the malfunction was from the socket, but this socket could not be found, cut the socket and canceled it, thus connecting the cable directly to the 3.stop lamp, approximately one months later, this annoying taillight bulbs started warning the fault, could the car be related to this, friends? 407 ERHAN 2017-05-20 08:08:27
Page : / 2
