The 406 driver's window is auto closed and it opens 3-5 inches back!
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 406
08.05.2020 16:46 # 1
toga406
Mrb. There was a situation with the automatic window closing of the vehicle, not from the heat, but once the
pressed, the glass itself closes or closes completely, but it hurts a little part of it. Whatever I did did not happen. Are there people who have the
problem or can someone come up with a solution? "Cry"
08.05.2020 16:46 # 2
toga406
I took care of the problem but I did not understand how. I kept it down, I kept it upside down But I don't understand how I believe it
08.05.2020 16:46 # 3
hsnsnl
If the upper part of the window is closed while the normal operation is closed, it will open the glass again.
08.05.2020 16:46 # 4
Muhammet
I had the same problem, I saw that the plastic on the top of the door was light, I pressed it with my hand and it was fine :) I think the glass was jamming and opens back. When you hold it down and then vice versa, the glass makes the automatic adjustment again. I saw the master doing glass while I saw it here:)
08.05.2020 16:46 # 5
toga406
but I guess my vehicle doesn't have a jam system
406 bva 2003 sv model but i guess there is no jam prevention in this
