The 307 right door does not open from the outside?
08.05.2020 20:27 # 1
Kazarus01
Hello friends, the original remote control of my 307 xt premium vehicle is malfunctioning.
08.05.2020 20:27 # 2
whisky
I think the manual lock is stuck when using the continous control, saying dust, dirt etc. Trying something like anahtarawd-40 on the lock may solve the problem.
08.05.2020 20:27 # 3
ruhela
My teacher had been in my last place, I went to the keymaker, the keymaker was working at the brother, brother wd40 said come with the hose, he put the wd 40 hose in place of the lock, emptied half of it, then inserted the key and forced it a little bit, opened the door.
I would say with the WD40, the pins in the previous key switches have shifted and said 200 TL. The guy said something, give me something.
08.05.2020 20:27 # 4
Kazarus01
Where will I drive the Wd40 open the door and lock part?
08.05.2020 20:27 # 5
talip206
Opening the door There is a black round rubber under the full lock. Pull it out, take the wd40 hose through the hole and get it there. Then insert the key into the hole and press the hose a little there. Take the key out several times. Finally, tighten the lock mechanism.
08.05.2020 20:27 # 6
Kazarus01
There is no key entry on the right door, only the driver is on my door. Then I just have to fuck in place of the lock
08.05.2020 20:27 # 7
talip206
[QUOTE = Kazarus01] Okay, there is no key entry on my right door, only the driver is on my door. Then I just need to fuck instead of locks, it hurts inside, not out of it [/ QUOTE]
Then remove the small round rubber under the lock and tighten it. When you open the door, you will see the place I mentioned
08.05.2020 20:27 # 8
zerzevat
There is also a capless white mechanism under the lock mechanism. round. the tip of the ignition key goes inside. If the vehicle's battery runs out, you can lock each lock separately from here using this mechanism on all doors. Finally, you lock the driver's door and go. turn this mechanism to the left or right several times. sometimes it gets stuck. It is tozlanıy. I took my hand so recently. I looked at the vehicle with the rear right door opening from the outside. I moved this mechanism a little, it improved. your problem can also be caused here. Mine is stuck open. yours is maybe stuck in locked position.
