THE 307 GAS REACTION PROBLEM
08.05.2020 20:05 # 1
conywolker
Hello to everyone,
As we know, is there anybody who solves the problem of late reaction in the first gas, which is our chronic problem?
I changed the spark plug, made LPG adjustment, Coil checked but not changed, no solution,
It makes both gasoline and LPG, but there is too much LPG in the departures, it seems to stop when it gets cold in the air ...
conywolk is 2016-12-16 14:43:08
08.05.2020 20:05 # 2
my throttle was cleaned hodja. it is necessary to clean and adapt. After cleaning the throttle, the vehicle needs to go at 100-150 km and create a new map map. Make sure it is 35 degrees and keep the gas above the half tank in winter. For the adaptation, which I will do the same operations, I will do the tour butterfly cleaning by myself. We will now choose either a private service or an authorized service.
08.05.2020 20:05 # 3
dejawu1978
I wonder how much this adaptation is made in price ...?
08.05.2020 20:05 # 4
Special price of 40-50 TL in private was at around 80-100 TL in the last authorized services.
08.05.2020 20:05 # 5
conywolker
[QUOTE = sonerkyl] my throttle was cleaned, sir. it is necessary to clean and adapt. After cleaning the throttle, the vehicle needs to go at 100-150 km and create a new map map. Make sure it is 35 degrees and keep the gas above the half tank in winter. For the adaptation, which I will do the same operations, I will do the tour butterfly cleaning by myself. We will now choose either a special service or an authorized service. [/ QUOTE]
The problem continues at the moment, gasoline has tremors at idle, sometimes it stops but there is no problem when it goes, it can rarely stop when it is wasted. There is no problem with relative relapse in the LPG, shaking, etc., but it is going to be extremely jerky at low speeds while driving, I have a very different version. I went to the master on Saturday called somebody for 307 there was a software update for the throat butterfly, I hope he will fix it tomorrow.
08.05.2020 20:05 # 6
dagdelen34
If you get it, you can write it down
08.05.2020 20:05 # 7
Narkotik
Look at the air flow meter
08.05.2020 20:05 # 8
conywolker
I wonder exactly where this air flow meter is
08.05.2020 20:05 # 9
conywolker
Also in the gasoline car is the flow meter
08.05.2020 20:05 # 10
Narkotik
Every vehicle has gasoline 307, on the manifold, behind the filter in the diesel
