The 307 center display lights went out.
08.05.2020 20:17 # 1
ben_erhan
Friends, I wanted to change the small indicator bulbs on the back of the screen with a led to find a solution to the fading that occurs when the heat on the middle screen .. I strip the led. none of them ever burned again ..
I have another spare screen. I transfer the inside of the 2 screens to each other. There is no problem in the lamps and the card .. Is there a problem in the card to which the screen glass is connected or the legs that supply electricity .. did I have a short circuit .. do I have a friend who has knowledge
08.05.2020 20:17 # 2
ggitaristt
how many meter led led do you connect?
08.05.2020 20:17 # 3
ben_erhan
5cm or something .. 3 LEDs with 3 chips with 12v ..
I went to an electrician today. I checked it with a spare screen .. a little black piece is broken. We removed the piece from the old screen and put it on the new screen.
08.05.2020 20:17 # 4
ggitaristt
There is no picture of that changing piece, right?
08.05.2020 20:17 # 5
ben_erhan
I'll take a picture if you want. A piece as black as lentils. One side is thick with one leg and the other side is three-legged soldered ...
08.05.2020 20:17 # 6
ggitaristt
[QUOTE = ben_erhan] I'll take your picture if you want. A piece as black as lentils. One side is thick, one leg and the other side is three-legged soldered ... I add it when I take a photo. [/ QUOTE]
No need to shoot, I understand from the recipe Big smile you have short circuit, the transistor is burned. Big smile I think RGB led for the complete interior lighting. When I want the color I want .. Example:
[TUBE] 7d2ıgesqfco [/ TUBE]
