text, can you take a look
08.05.2020 16:11 # 1
brother dun vehicle and I pressed it for 8 km, then I closed the vehicle and then stopped the vehicle and within 1 hour it was so much oil under the vehicle is it normal
< div>
< div> Reviews
Reviews
Reviews
08.05.2020 16:11 # 2
metin
not normal at all. I wonder if those who revised did not squeeze the pieces well. Apparently only when the vehicle is squeezed.
& nbsp;
is as much as to throw away the excess oil that I mentioned to you. In other words, if the oil is too tight, it throws it away and goes down to its normal level. Even if you squeeze it because its level is normal, there is something else in this business. If you are looking for plain compression, there may be a problem with the cover, gasket, etc.
08.05.2020 16:11 # 3
fexzi
If there is a change of oil in a short time, I can escape from the sealing of the stopper in the crankcase and check it.
08.05.2020 16:11 # 4
If you did not know exactly from the engine but you did not know exactly from the engine, I do not know if I have to discharge the oil completely and change the oil & nbsp;
08.05.2020 16:11 # 5
metin
When the oil cools the vehicle, it reaches high pressures when it warms up, and its volume increases in liters because it expands. the excess is thrown from the evacuation, but not the excess is thrown.
& nbsp;
There is a cover with solenoids on the front. If you look around it, I suspect it is usually thin sheet, the best method is better if you come down under the vehicle and take a picture of it. Although you can't see it, there is a place where this oil comes out.
& nbsp;.
08.05.2020 16:11 # 6
okay brother I will go to the industry in a moment I look at the places & nbsp; I try to take a photo
08.05.2020 16:11 # 7
OkaN
can squeeze it from the top cover but not so much :) it may be in the times & nbsp;
08.05.2020 16:11 # 8
I went to the text, today, the masters in the service looked at the oil, it is not certain where it came from, it is not like the oil transmission oil. ))
